Understanding Capacitive Circuits: The Relationship Between Current and Voltage
  • Thread starter Thread starter XPTPCREWX
In a purely capacitive circuit, the phrase "current leads the voltage by 90 degrees" refers to the relationship between current and voltage waveforms, where current reaches its peak before voltage does. This is explained through differential equations, indicating that current must flow to charge the capacitor before a voltage can develop across its terminals. The terminology can be confusing, as it implies a non-causal relationship, but it simply describes the nature of continuous waveforms in capacitors. Understanding this concept is fundamental in AC circuit analysis. The discussion emphasizes the importance of grasping these principles for a clearer understanding of capacitive behavior.
XPTPCREWX
Perhaps some one can explain to me what is meant by "current leads the voltage by 90 degrees"...let this inquiry be in regards to a purely capacitive circuit.
What seems to baffle me is why this terminology is used. Its not like the current just decided to occur before a potenial difference.
It's easiest to get comfortable with this concept based on the differential equations for the currents and voltages for inductors and capacitors.
For Capacitors, the driving function is the current, which charges up the capacitors:
v(t) = \frac{1}{C}\int{i(t) dt}
The voltage across a capacitor cannot change instantaneously, because that would require an infinite current.
Similarly for Inductors, the driving function is the voltage, which ramps up the current:
i(t) = \frac{1}{L}\int{v(t) dt}
The current in the inductor cannot change instantaneously, bacause that would require an infinite voltage. The current can change very quickly, however, like in a flyback power supply circuit that is pumping a high voltage...
So when we say that the current lags the applied voltage in inductors, or that the voltage lags the applied current in capacitors, we are just saying in words what you get from the differential equations that describe the physics of those components.
And when we say "the current leads the voltage...", we are not describing something non-causal. It's just a bit of a confusing way to state the relationship the other way around, and for a continuous waveform.
Hope that helps.
Really helps...Thanks.
To make it very simple. Before the cap can have any voltage across it's terminals, you need to charge it up. So current has to be pumped into the cap before the cap can charge up to have voltage. Current always have to come first so it lead the voltage! This is the ABC way to explain it!:smile:
Berkeman has given you the detail of the rest.
yungman,
Actually it isn't that simple. there is obviously a potential difference between the applied voltage and the capacitors terminal voltage to create that current flow in the first place.
Berkeman has explained it to me the best so far.
XPTPCREWX said:
yungman,
I am glad you are happy with berkeman's answer. This is a very simple question that you find in the first few lessons of AC circuits, so I want to give a very simple answer just in case. I just add this in because there are people that don't do calculus! I was one of those long time ago!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
