Calculating Capacitive Reactance for 10V, 2.5kHz, Sine Wave
  • Thread starter Physixs
  • Tags
    Reactance
In summary: Nothing really, I just looked up Capacitive reactance on wiki and saw an equation using j, which is the square root of -1. But that thing was mentioning phasors and stuff, so I don't know.Since the capacitive reactance and the resistance are at right angles, you need to use the squareroot of the sum of the squares to determine the magnitude of the sum. What is the magnitude of Z = R + jw/C.Since the capacitive reactance and the resistance are at right angles, you need to use the squareroot of the sum of the squares to determine the magnitude of the sum. What is the magnitude of Z = R + jw/C.
Physixs
31
Hello again, I am trying to knock out some challenge questions in my text (to prepare for my midterms) and I came across this question.
A 10V, 2.5kHz, sine wave is applied to a series combination of a 0.01µF capacitor and a 10kΩ resistor. What would the total current be?
The answer in the back of the book says 0.844mA
I am not getting anything anywhere near that. Can someone please tell me where I am thinking incorrectly? Thanks.
Here is my thought process.
First, calculate the capacitive reactance: 1/2πfC = 1/(2πx2500x0.1x10^-6) = Xc = 6366.2Ω
This is where I think I am going wrong.
since the capacitor and the resistor are in series, so i added the capacitive reactance and resistance together: 6366.2 + 10,000 = 16,366.2Ω
I then applied ohm's law to get 10/16366.2 = 0.611mA which is way off
Using backwards design, I figured 10/0.844mA = 11,848Ω
which means that in some way shape or form, my total resistance in the circuit should be 11848Ω
I cannot figure out how to get my Xc of 6366.2Ω and resistor 10k to combine in a manner that would be 11848Ω
Any insight would be great!
Thanks!
You don't need to multiply Xc by the square root of -1 or something do you?
I don't think so? Is there an equation or reason that I should? I don't think this chapter has had any mentioning of imaginary numbers. What was your idea?
Likes 1 person
Interesting. I just tried that out and you are absolutely correct! What worries me about this, is that the chapter section on capacitive reactance has NO MENTION of this and there are no sample problems like this. I will have to do some research to figure out why this is...
I can't even picture why they would be perpendicular to one another.
Maybe ill ask my TA again next week.
That's actually pretty easy. Reactance is modeled by (I hate this term) imaginary numbers, but in simple terms what happens is that there is a phase shift of 90 degrees between the voltage and current caused by the capacitor. The current through the capacitor leads the voltage (essentially it takes time to charge the capacitor) It is described nicely in this tutorial: http://www.electronics-tutorials.ws/accircuits/AC-capacitance.html and there is a nice diagram to demonstrate the effect.
Inductors have the same effect except the voltage leads the current.
BTW, for a series LC circuit when the lead in the inductor = the lag in the capacitor you get resonance and the impedance is zero.
Likes 1 person
That is perfect! I wish you wrote my textbook! Thank you so much!
FAQ: Calculating Capacitive Reactance for 10V, 2.5kHz, Sine Wave
1. What is the formula for calculating capacitive reactance?
The formula for calculating capacitive reactance is Xc = 1/(2πfC), where Xc is the capacitive reactance in ohms, π is the mathematical constant pi, f is the frequency in hertz, and C is the capacitance in farads.
2. How do I find the frequency for my calculation?
In this scenario, the frequency is given as 2.5kHz. If you need to find the frequency for a different scenario, you can use a frequency generator or find the frequency from the source of the sine wave.
3. What is the value of pi in the formula for calculating capacitive reactance?
The value of pi is approximately 3.14, but for more precise calculations, you can use a more accurate value such as 3.14159.
4. How do I convert voltage to capacitance for this calculation?
The voltage is not needed for calculating capacitive reactance. Instead, you will need to know the capacitance in farads. If the capacitance is given in a different unit, you can use a conversion factor to convert it to farads (1 farad = 1 coulomb/volt).
5. Can this formula be used for any type of sine wave?
Yes, this formula can be used for calculating capacitive reactance for any type of sine wave, as long as the frequency and capacitance are known. However, it is important to note that this formula is specifically for a 10V, 2.5kHz sine wave, so the values may be different for other scenarios.
9K
