Capacitor Charging Circuit Question
In a high voltage boost converter charger circuit for capacitors, an LED indicates when charging is complete by detecting the voltage across the capacitor. The charger typically uses a feedback mechanism to monitor the voltage level, signaling when the capacitor reaches its full charge. Upon completion, the circuit may disconnect the capacitor or shut off the charging process to prevent overcharging. This ensures the safety and longevity of the capacitor. Understanding these mechanisms is crucial for designing efficient charging circuits.
kjjohn
I understand what a capacitor charging circuit looks like, and know how it works. My question is, with an HV boost converter charger, for charging high voltage caps, there is often an LED that lights when charging is complete. How does this work - how does the charger know when the capacitor is full? And does it actually disconnect the cap from the circuit or shut off the circuit after the cap is completely charged?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
