Capacitors for power utilities and electric apparatus
The discussion revolves around a request for information on the types of capacitors used in power utilities and electric apparatus, specifically asking if they are aluminum, tantalum, or other types. A suggestion is made to utilize Google to find the company's website for detailed information. The inquiry reflects a need for clarity on capacitor types relevant to the industry. The responses emphasize the importance of online resources for research. Overall, the conversation highlights the quest for specific technical information regarding capacitors in electrical applications.
wzheng1837
Hi!
I am doing a research on a specific company and they made 'Capacitors for power utilities and electric apparatus'.
Would someone be so nice to tell what kinds of capacitors they are? (Aluminum, tantalum, etc?)
Thanks!
wzheng1837 said:
Hi!
Thanks!
Hi wzheng1837. I reckon google.com should be able to lead you to the company's web pages and the information you seek. :smile:
Good luck!
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
