Why is my car acceleration not matching the calculated force?
  • Thread starter Thread starter Jonsson
    Acceleration Car
The discussion centers on the discrepancy between the calculated force required for a car's acceleration and the force derived from the engine's torque. The car, weighing 900 kg, accelerates to 27.7 m/s in 8 seconds, suggesting a force of 3116 N, while the torque calculation yields only 666 N. The key issue identified is the neglect of gear ratios, which significantly affect the effective torque delivered to the wheels. The conversation highlights the importance of considering the gearbox and final drive ratios in calculating acceleration forces. Overall, the analysis must account for multiple gears during acceleration to accurately reflect the car's performance.
Jonsson
Hello there,
Just got an old car, and I was looking at the specifications, and trying to teach myself Newtonian physics. But I cannot get it to work out correctly. Please tell me where I go wrong.
The car weighs 900 kg. The engine has 200nm of torque, it accelerates from still to 27.7 m/s in 8 seconds. The radius from the center of the drive axle to the outside of the tire is circa 0.3m.
F = m\,a
Assuming constant acceleration:
F = m\frac{v}{t}
F = 900\mathrm{ kg}\frac{27.7\mathrm{ m/s}}{8\mathrm{ s}}
F = 3116\,\mathrm{ N}
So, to go from zero to 100km/h in 8 seconds takes 3116 N. This is not taking aerodynamic drag and drivetrain friction into account.
This is where I go wrong I think. The car has 200 Nm of torque:
\tau = 200\,\mathrm{Nm}
I have an arm of 0.3m (the distance from the centre of the wheel to the outside of the tyre)
F = \frac{\tau}{r}
F = 666 N
The problem is 3116\,\mathrm{ N} >> 666\,\mathrm{ N}
And this is without even taken aerodynamic drag and drivetrain losses/friction and all of that jazz into account.
How come my maths is off by so much?
Thank you for your time.
Kind regards,
Marius
NOTE: Looks like my numbers may be off by a factor of 2∏ ? Not sure where it should go though.
You have to take the gear into account, it can increase the torque (and reduce the rotation frequency).
Quick check: a typical wheel has a diameter of ~50cm. At 30m/s, it rotates with 1200rpm. That is not the range where you operate the engine to accelerate.
These are the gear ratios of the car:
1st 3.80 : 1
2nd 2.06 : 1
3rd 1.26 : 1
4th .89 : 1
final drive ratio 4.125 : 1
Do you think I am right in multiplying the ratio of the gear with the differential final drive ratio?
F = 200Nm * gear ratio * final_drive_ratio/0.3m
Kind regards,
Marius
That's what a gearbox is for. You have a higher overall gear ratio when starting in first gear to keep the engine from stalling. Once the car is moving, you change gears to reduce the overall ratio until you reach the point where the wheels are rotating at a speed which won't cause the engine to stall, and the engine is turning at sufficient RPM to keep the car moving at a constant travel speed.
When you are accelerating to speed, unless you do it in a single gear, the analysis in the OP is not valid.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
