Automotive How do bolts hold a car's subframe in place?
  • Thread starter Thread starter TheTallJS
    Car Falling
The discussion highlights the surprising strength of bolts that secure a car's subframe, emphasizing that it is the friction generated by the tension in the bolts, rather than sheer strength, that keeps the subframe in place. A low-strength steel bolt can handle significant stress in tension, with calculations showing it can support over 10,000 pounds of force. Even with reduced friction, the bolts maintain substantial shear strength, capable of withstanding thousands of pounds. The use of high-strength bolts further enhances this capacity, ensuring safety under various driving conditions. Overall, the combination of bolt tension and friction is crucial for maintaining the integrity of a car's subframe.
TheTallJS
It boggles my mind how a car's subframe is only held on by a few bolts and some rubber bushings. How is it that the bolts don't just shear off? It would seem that the forces of driving, sometimes erratic, should easily overcome the strength of a bit of metal.
People have been putting in aftermarket polyurethane bushings and even solid aluminum bushings into their subframes, and I can't help but wonder how long before those bolts snap. Or if those bolts are of sufficient strength, that they tear through the car's body where the bolts are bolted in to.
Actually, solid bushings seem very appealing. Maybe reducing sprung/unsprung weight would reduce forces that would otherwise cause damage on an unmodified car.
It is not the bolt shearing strength that holds 2 pieces together, it is the friction force caused by the compression generated by the bolt's tension.
A low-strength steel bolt can withstand 55 000 psi of stress in tension before permanent deformation occurs (i.e. tension when correctly torqued). For a ½" bolt, that is 10 800 lb of force (##= 55 000 \times \frac{\pi}{4}0.5^2##). With a friction coefficient of 0.6, it means the friction force is 6500 lb between the 2 sandwiched plates. Even with a friction coefficient of 0.2, you still have 2100 lb of friction force.
Even if friction is not present, the shear strength is usually 58% of the tension strength, so 32 000 psi for a low-strength steel bolt. In single shear, a ½" bolt can still support 6200 lb of force.
It is usual to use high-strength bolts in those situations, which can withstand twice as much.
Likes TheTallJS
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
