Do Car Engines Operate on the Carnot Cycle?
Car engines do not operate on the Carnot cycle, as it is a theoretical model that represents an idealized heat engine. Instead, most car engines, particularly gasoline engines, typically follow the Otto cycle, which is more practical for real-world applications. The Carnot cycle is used primarily for understanding the limits of efficiency in heat engines rather than as a direct representation of how car engines function. Discussions emphasize the importance of understanding different thermodynamic cycles to grasp engine operations fully. Overall, car engines utilize specific cycles that differ significantly from the Carnot cycle.
person_random_normal
are engines in our cars follow the carnot cycle or they work differently
no carnot cycle is a theoretical one.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
