Car's coefficent of kinetic friction help
The discussion revolves around calculating the coefficient of kinetic friction (uk) and stopping distance for a 1500 kg car skidding on a wet asphalt road. Initially, a user calculated uk as 1.2 with a stopping distance of 60 meters but later revised it to uk = 0.53 and a distance of 38.2 meters. Participants noted inconsistencies in the initial values and questioned the source of the original coefficient. The final consensus indicates that the correct coefficient of kinetic friction is 0.53, leading to a stopping distance of 38.2 meters. Accurate calculations are crucial for understanding vehicle dynamics in emergency situations.
pharaoh
you are driving a 1500 kg car at a constant speed of 20 m/s along Grand Blvd. a wet road, asphalt level road. as you approach the intersection, you get a call on your cell phone. then you forgot about the stop sign. when you see the stop sign you slam on the brakes 20 meter from the intersection. the car's wheel lock, the tire begin skidding and the car slides to a halt. what was your coefficent of kinetic friction (uk) and how far did you ge before stopping?
i got uk= 1.2 and d= 60 m but i am not sure
Those two numbers are not consisteent with one another. Where did you get uk? Did you look it up in a table?
thanks for replying but i found the answer
uk= 0.53 and the d= 38.2
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
