Car's maximum acceleration on a road is proportional to what?
- Thread starter rudransh verma
- Start date
94 replies · 9K views
rudransh verma
- 96
But I was close to understanding what @jbriggs444 was telling about the distribution of force onto four wheels. I only didn’t understand the last line.Doc Al said:As others have pointed out, treat the car (including its tires and all other parts) as a single object. Treating the tires as separate objects only creates more work with no advantage.
But now you are saying that treat it as a single body which is difficult to understand.
So can you explain me that last line only?
jbriggs444 said:The the net force (the sum of the rearward force from body of the car and the forward force from friction with the road) on each wheel must be ma in order to satisfy Newton's second law.
Mentor
- 45,589
- 2,482
Sure. You could treat the tires separately. But the tires are connected to the rest of the car -- the tires push the car forward and the car pushes back on the tires. (Newton's third law!) If you want to call the force the car body exerts on a tire ##F_a##, well now you have to solve for that!rudransh verma said:But I was close to understanding what @jbriggs444 was telling but the distribution of force onto four wheels. I only didn’t understand the last line.
But I cannot imagine why you'd do it that way. Treating the car as a whole, you have friction on the tires (which are part of the car) ##f_s## and the mass of the car. Finding the acceleration is one step away.
Mentor
- 45,589
- 2,482
Treating the tires separately is overcomplicating a simple problem. (As another example: Say you need to calculate the acceleration of a block on a frictionless surface when you push with some force F. Do you break the block into pieces, like front half and back half? Well, you could -- you'd get the same answer with a bunch of unnecessary work.)
(And I don't think @jbriggs444 was recommending any such thing.)
Mentor
- 45,589
- 2,482
Another way of saying the point @jbriggs444 was making: Take any piece of the car -- a tire, the steering wheel, whatever -- Newton's 2nd law must apply. The net force on that piece must equal ##ma##, where ##m## is the mass of that piece.rudransh verma said:So can you explain me that last line only?
rudransh verma
- 96
How does the tire push the car? Are you talking about the force that engine delivers?Doc Al said:-- the tires push the car forward and the car pushes back on the tires. (Newton's third law!)
Mentor
- 45,589
- 2,482
The tires are connected to the car. The road (via friction) pushes on the tires and the tires push on the rest of the car. (And the rest of the car pushes back on the tires, of course.)rudransh verma said:How does the tire push the car?
No.rudransh verma said:Are you talking about the force that engine delivers?
bob012345
- 1,116
The torque turns the wheel but because of the static friction between the wheel and the road, the wheel pushes on the road and the road pushes back on the wheel according to Newton's Third Law. The wheel then transmits that force to the rest of the car and the whole car accelerates together.rudransh verma said:Why? What about the torque delivered by engine to the wheels?
Again, the torque is an internal torque between the wheel and the rest of the car. It cancels out when you treat the car as one single unit. All you have left with is the whole car of mass ##m## and the friction force which accelerates the car. You actually had the correct answer above in post #15 but you gave the wrong reasoning.
Note that the only time you might have kinetic friction between the tires and the road is if you are burning rubber or sliding on a wet or icy road.
- 10,068
No, it doesn't, it is applied at the axle on the shown figure. That is the applied force to the body that the OP is looking for; assuming the wheel mass is included with the body of the car for simplification.bob012345 said:Yes but even this is leaving out the force between the body of the car and the wheel which I am in favor of
No, there is no torque applied to consider when analyzing the whole car.bob012345 said:but we should not say this is the diagram of the wheel alone but that it represents the whole car in this problem.
The wheel torque explains why the friction force seems to be "backward" compared to a sliding block. This is what the OP doesn't seem to understand. The wheel mechanism reverses the friction force direction, thus propelling the car instead of braking it.
rudransh verma
- 96
Edited:bob012345 said:The torque turns the wheel but because of the static friction between the wheel and the road, the wheel pushes on the road and the road pushes back on the wheel according to Newton's Third Law. The wheel then transmits that force to the rest of the car and the whole car accelerates together.
Ok! I got it now! So as I was thinking ##F_a(applied force by the wheel)=f_s##.static friction. Both ##F_a## and ##f_s## are necessary for acceleration of the car. Without ##F_a## there is no ##f_s## and without ##f_s## car would not accelerate.
So, $$f_s=ma$$
M is mass of car body and m is mass of tyre.
And the rest is same in #post15.
Newtons laws hold true!
Thanks everyone!
rudransh verma
- 96
jbriggs444 said:If we assume that this is a four-wheel drive vehicle with all four wheels contributing equally then each wheel will contribute 1/4 of the force required to propel the body of the car forward. By Newton's second law, the total forward force from wheels on car body must be Ma. By assumption, each wheel contributes 1/4 of that. That is, the force between each wheel and the body of the car will have magnitude Ma4. Or (M/4)a if you prefer.
Homework Helper
- 13,438
- 8,110
Incorrect. Please provide your reasoning for this assertion.rudransh verma said:$$ma=(M/4)a$$
rudransh verma
- 96
Four frictions ma provide four forces to the wheels and that inturn provide necessary force Ma to the body of the car.jbriggs444 said:Incorrect. Please provide your reasoning for this assertion.
Homework Helper
- 13,438
- 8,110
No. The force with which the road pushes on the wheels is not identical to the force with which the wheels push on the car's body.rudransh verma said:Four frictions ma provide four forces to the wheels and that in turn provide necessary force Ma to the body of the car.
Let us go back to the assertion that you had made:$$ma = (M/4)a$$We divide by ##a## to get$$m=M/4$$But that is an assertion that each wheel has mass equal to 1/4 of the car's mass.
No. They do not.
rudransh verma
- 96
Yeah! Right! Then?jbriggs444 said:But that is an assertion that each wheel has mass equal to 1/4 of the car's mass.
Homework Helper
- 13,438
- 8,110
Well, the point is that you are working the problem incorrectly, jumping boldly to unjustified conclusions. The proper response to that would be to solve the problem correctly.rudransh verma said:Yeah! Right! Then?
Pick variable names for the relevant quantities and document them. Enumerate the forces acting on each free body. Write down equations that you can justify, typically using Newton's second or third laws. Include the justification along with the equations. Solve the equations. Show your work. Check your answers to see if the solution you derive actually fits the givens of the problem.
rudransh verma
- 96
Hmm! Right but now I am tiredjbriggs444 said:correctly.
Pick variable names that you have documented. Enumerate the forces acting on each free body. Write down equations that you can justify,
bob012345
- 1,116
Frankly, I'm a bit confused looking at this free-body diagram. Is it for just the wheel or the whole car? It seems it would be hard to understand in either case since all the forces apparently cancel out even though it assumes the case of acceleration.jack action said:No, it doesn't, it is applied at the axle on the shown figure. That is the applied force to the body that the OP is looking for; assuming the wheel mass is included with the body of the car for simplification.No, there is no torque applied to consider when analyzing the whole car.
rudransh verma
- 96
This diagram is confusing me too since friction>force applied by the wheel.bob012345 said:Frankly, I'm a bit confused looking at this free-body diagram. Is it for just the wheel or the whole car? It seems it would be hard to understand in either case since all the forces apparently cancel out even though it assumes the case of acceleration.
bob012345
- 1,116
Ignore the green friction. That is something called rolling friction which is a different kind of resistance to rolling motion and is not considered in your problem. The only friction you need for this problem is static friction, what they gave you, because the wheel is not slipping with respect to the ground. The wheel applies a force to the ground and the ground applies a force to the wheel. The wheel accelerates forward and the ground (road) accelerates backward (again Newton's Third Law) but at such an imperceptibly small rate as to be considered zero.rudransh verma said:This diagram is confusing me too since friction>force applied by the wheel.
Also note, you were not given the mass of the wheels, just the car as a whole. That is a big clue you don't need to treat this as a complicated problem with multiple parts. Just one car as a whole of total mass ##m##.
rudransh verma
- 96
I may have missed something before but I am again asking if it’s static friction between the road and tyre how is the tyre/car accelerating?bob012345 said:Ignore the green friction. That is something called rolling friction which is a different kind of resistance to rolling motion and is not considered in your problem. The only friction you need for this problem is static friction, what they gave you, because the wheel is not slipping with respect to the ground. The wheel applies a force to the ground and the ground applies a force to the wheel. The wheel accelerates forward and the ground (road) accelerates backward (again Newton's Third Law) but at such an imperceptibly small rate as to be considered zero.
bob012345
- 1,116
It is static friction that allows the car to roll. Rolling is not slipping. As a wheel rolls each point comes in contact with the road without sliding. Try it yourself with a small wheel. Mark a point and watch it as you roll it. The point does not slide as in kinetic friction.rudransh verma said:I may have missed something before but I am again asking if it’s static friction between the road and tyre how is the tyre/car accelerating?
rudransh verma
- 96
bob012345 said:It is static friction that allows the car to roll. Rolling is not slipping. As a wheel rolls each point comes in contact with the road without sliding. Try it yourself with a small wheel. Mark a point and watch it as you roll it. The point does not slide as in kinetic friction.
Homework Helper
- 13,438
- 8,110
What do you mean when you say "applied force"? If you do not tell us what force you are talking about, we cannot tell whether it is static friction.rudransh verma said:But this static friction = applied force. Right?
rudransh verma
- 96
The torquejbriggs444 said:What do you mean when you say "applied force"? If you do not tell us what force you are talking about, we cannot tell whether it is static friction.
Homework Helper
- 13,438
- 8,110
No. The torque is not equal to the force of static friction. The two do not even have the same units. Torque is also not what I would have expected "applied force" to have meant.rudransh verma said:The torque![]()
rudransh verma
- 96
- 10,571
It is the OP that has complicated it by worrying about the wheels separately. See post #15.bob012345 said:Yes, It seems to me we are overcomplicating a very simple problem and it is not helping the OP understand the physics in my view.
bob012345
- 1,116
Of course they accelerate because they move along with the car.rudransh verma said:Are you saying the tyres do not accelerate. It’s the rolling not sliding that is going on. Static friction is causing the roll. And that is creating the acceleration in the car.
I'll try something else here. Take your finger and push against a surface. Do not let it slip[. If the surface is loose it will move, if it is rigid it will resist moving and you might move a bit opposite to your push. A tire is just like having an infinite set of fingers that can push against the road as each one comes in contact.
Or else, take a little wheel and roll it along a table. Apply torque with your hand and feel how the wheel wants to move.
Homework Helper
- 13,438
- 8,110
The tires do accelerate. Otherwise they would be left behind, begging for the car to "wait up".rudransh verma said:Are you saying the tyres do not accelerate. It’s the rolling not sliding that is going on. Static friction is causing the roll. And that is creating the acceleration in the car.
Yes, it is rolling rather than sliding. This allows the bulk of the tire to move forward while the contact patch remains (nearly) stationary while it is in contact with the stationary road.
Static friction does not cause the roll. It resists the roll. The force of static friction forward on the bottom of the tire tends to reduce the tire's roll rate. The engine (and transmission and differential) forces the roll. The roll causes the strain that causes the static friction.
- kneu
- · Replies 3 ·
- Introductory Physics Homework Help
- Replies
- 3
- Hailcanadien
- · Replies 2 ·
- Replies
- 2
- rrosa522
- · Replies 3 ·
- Replies
- 3
- Jazz
- · Replies 3 ·
- Replies
- 3
- iiiabhiiii
- · Replies 4 ·
- Engineering and Comp Sci Homework Help
- Replies
- 4
- jhk_1945
- · Replies 1 ·
- Replies
- 1
- StephenDoty
- · Replies 3 ·
- Replies
- 3
- mcgooskie
- · Replies 3 ·
- Replies
- 3
- Hollysmoke
- · Replies 15 ·
- Replies
- 15
