Cation Solubility: Relationship with Element Position?
  • Thread starter Thread starter Tom McCurdy
    Solubility
Cation solubility is influenced by both the position of the element in the periodic table and the type of anion present. While some cations, like calcium in calcium nitrate, are generally soluble, others, such as calcium sulfate and calcium carbonate, exhibit low solubility. The solubility of hydroxides varies, with lighter cations like beryllium and magnesium being insoluble, while heavier cations like calcium are soluble. The ionic bond length increases down a group, resulting in lower energy requirements for dissociation, which can affect solubility. Additionally, the hydrated radius of a cation may correlate with its ionic strength and activity, suggesting a complex relationship that can be further explored using the Debye-Hückel equation.
Tom McCurdy
I was wondering if their is a reltionship between cation solubility and the poistion of its element in the periodic table?
Chemistry news on Phys.org
Not that simple. Aqueous solubility depends on the anion as well.
For example, {\text{Ca}}\left( {{\text{NO}}_{\text{3}} } \right)_{\text{2}} is (obviously) soluble, whereas both {\text{CaSO}}_{\text{4}} and {\text{CaCO}}_{\text{3}} are insoluble (dissolve in small and likely insignficant amounts in water). All nitrates are generally soluble and carbonates are generally insoluble.
There are cases where the cation position on the periodic table does matter. For example, both {\text{Be}}\left( {{\text{OH}}} \right)_2 and {\text{Mg}}\left( {{\text{OH}}} \right)_2 are considered insoluble, whereas {\text{Ca}}\left( {{\text{OH}}} \right)_2 and the heavier alkalines are soluble.
*Generally, what you observe is a longer ionic single bond length for heavier cations, which will take successively less energy to dissociate going down a group of the periodic table. (that said, I'm pretty sure that double-bonded MgO is insoluble).
For some of the rules of solubility, click http://chemed.chem.purdue.edu/genchem/topicreview/bp/ch18/soluble.html#rules ! :smile:)
-Hope this helps
perhaps you're referring to the hydrated radii of a cation, I think that you may be able to correlate this with its trends in ionic strength, and then with the activity (perhaps with a plot of activity v.s. increasing formal concentration); if at suitable concentrations by using the debye huckel equation. There may be a better way, or even a standard method. You may want to researcht the d-b equation.
thanks for your replies
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
