Cauchy expansion of determinant of a bordered matrix
The discussion centers on the Cauchy expansion of the determinant of a bordered matrix, specifically the formula involving a principal submatrix A. The original poster questions whether a similar determinant expression holds when A is not a principal submatrix. A participant confirms that a related expression does exist, stating it as a rearrangement involving the adjugate of A. They also note that the relationship between such matrices can be understood through permutations, which affect the determinant's sign. This highlights the broader applicability of the Cauchy expansion beyond principal submatrices.
ekkilop
The Cauchy expansion says that
\text{det} \begin{bmatrix}<br /> A &amp; x \\[0.3em]<br /> y^T &amp; a<br /> \end{bmatrix}<br /> = a \text{det}(A) - y^T \text{adj}(A) x,
where A is an n-1 by n-1 matrix, y and x are vectors with n-1 elements, and a is a scalar.
There is a proof in Matrix Analysis by Horn and Johnson that seems to be based on that A is a principal submatrix. My question is whether some similar result holds if A is not a principal submatrix? Say that we look for
det\begin{bmatrix}<br /> y^T &amp; a \\[0.3em]<br /> A &amp; x<br /> \end{bmatrix}<br />.
Would a similar expression hold?
Thanks.
Thanks.
Indeed. In fact, it would just be ##\vec{y}^T \operatorname{adj}\textbf{A} \vec{x} - a\operatorname{det}\textbf{A}##. Can you see why? :-p
Hi!
It just dawned on me that any such matrices (I suppose there are only 4 places A could go ^^, ) are related by simple permutations. Since any permutation matrix has determinant + or - 1 then what you say must be true.
Thank you for the enlightenment! =)
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
  • · Replies 24 ·
  • · Replies 23 ·
