Cause of the Soret Effect/Thermophoresis?
  • Thread starter Thread starter Declan
    Cause
The discussion centers on the unexpected behavior of a gas mixture of helium (He) and argon (Ar) during thermophoresis, where argon moves toward the hot side instead of helium, contrary to expectations. The user is simulating this effect between plates at extreme temperatures (500K and 5K) and is unsure if the high temperature gradient is influencing the results. References to the Soret coefficient and Onsager reciprocal relations are made, indicating a complex interplay between diffusion and thermal conduction. The user seeks clarification on whether the separated gases would remain stable without convection after separation. Overall, the conversation highlights the challenges of simulating thermophoresis under extreme conditions and the need for further understanding of the underlying physics.
Declan
Hi everyone! I'm simulating a gas mixture of He and Ar, and I'm trying to get them to separate via Thermophoresis. For clarification, http://en.wikipedia.org/wiki/Thermophoresis
When I naively try it with what I have so far in my program, it exhibits Thermophoresis...but with the Ar going to the hot side and He going to the cold side! The wiki says it should generally be the opposite (lighter molecule, He, going to the hot side), and I was told by my professor to expect this as well.
Generally, when something doesn't work, I try to understand the physics behind what should be happening, and go from there. But I've got to admit...I have no idea why this effect happens! I tried a bit of googlin', but came up with nothing. I can't really think of why the gas would separate.
Right now, I'm putting a 50/50 He/Ar mix between one plate at 500K and another plate at 5K. The distance between the plates is about a micron and a half. This does seem like a really high temperature gradient, so maybe that's messing something up. But then again, I don't really know why this works or why what I'm doing could be bad.
Does anyone know? Can anyone help me?
Thanks!
Science news on Phys.org
Interesting...
The Soret coefficient comes out of the Onsager reciprocal relations, and couples diffusion and thermal conduction. The inverse effect (concentration gradient leading to the temperature difference) is called the Dufour effect.
I don't have much material on it, but there's a section in DeGroot's "Thermodynamics of irreversible processes"
I also found this:
http://www.springerlink.com/content/r144275286w56k64/
and this (measurements at lower temps, but maybe applicable):
http://pof.aip.org/resource/1/pfldas/v4/i10/p1216_s1
Andy Resnick said:
Interesting...
I also found this:
Cool, I'll take a look at those. Thanks!
Looking at the working examples my professor showed me, he the gas in between a plate at 300K and one at 2000K...with the plates being 1m apart. So, relatively, that's a waaay smaller temperature gradient. It's possible it breaks or something when you're doing such extreme conditions as mine.
Well, let me go read those.
Hmmm. Read a bit, can't say I'm clearer on it.
A question about thermophoresis, if you know the answer: once the gas has separated, it should roughly stay in place, right? As in, there isn't much convection going on, right?
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
