Should I buy an aftermarket battery for my old Sony Ericsson T200 phone?
In summary: They would be more likely to be knockoffs that may not have the same quality as the original battery.
DaveC426913
6,168
My Sony Ericsson T200 cell phone is ~4 years old. (I know, vacuum tubes and dial knobs). It is no longer made. Thus, they no longer make the batteries either.
My battery's life has become quite short, lasting only a day or two without use (it used to last all week), so I'd like to replace it.
A guy at the Fido booth suggests that I can get an aftermarket battery, but those batteries will not be nearly as good as the original (I don't know if he means because they're old or becasue they're knock-offs). Anyway, the number he threw out was 30%, meaning I might only get 30% performance out of them (which is about what I'm getting now).
My question: are these after-market batteries less able to perform - for whatever reason - than my original?
Computer science news on Phys.org
Most cell phone companies are giving away phones for free that are much more sophisticated than what you have. Time to let go Dave. I have my 6 lb Ericson cell phone in my closet. There comes a time when you just...have...to...let...go.
Put the phone down Dave. PUT IT DOWN. BACK AWAY FROM IT. It had a long and happy life, but all good things must come to an end.
Oh, and while you're at it, you might as well give up your 8 track tape deck and BetaMax. They're not coming back either Dave. :uhh:
Aftermaket batteries that will fit your phone are most likely made by the same company that made the original battery.
Sounds like a lot of hype to me.
OTOH Evo has a point.
It will probably be cheaper to get another phone :grumpy:
< rant >
My phone can
- call people
- receive calls
That's all a phone needs to do
All the rest just means longer and deeper menus and crap.
I'm not some attention-deficit teen whose phone was bought by their parents and who doesn't pay the bill so I can text message jokes and play video games all day.
< /rant >
Evo: 'sophisticated' does not equate with 'useful'. The new phones have no benefits over my current phone.
Also, those phone upgrades invariably come with prepaid contracts. I am on pay-as-you-go. So those phones are at full price.
DaveC426913 said:
< rant >
My phone can
- call people
- receive calls
< /rant >
Go to Walmart and get one of those no frills "pay as you go" phones. I'm the same way, I only want my phone to make and receive calls, and that's all it does. It cost me $39. I only recharge my battery every 6 days, and that's with it always on and daily use. (I'm not a heavy user)
But ... but ...
I have a phone.
DaveC426913 said:
But ... but ...
I have a phone.
A new battery will work the same as the old battery before it went bad.
How much will the new battery cost?
Probably more than Evo's solution :grumpy:
I'm with Evo on this one, time to say goodbye.
New batteries cost as little as $35.
Still, my question isn't getting answered (well, except for NoTime, who has, twice). Are after-market batteries lower quality than brand name batteries, specifically when it comes to stand-by life? I'd prefer an educated opinion over a guess (but I'll take what I can get).
Consumer Zombies.:biggrin:
Hmmm $39 vs $35, not much of a difference there.
Does that include shipping?
One thing you haven't considered is a possible defect in the phone that has caused an increase in standby load. If you don't have the tools to verify the correct operation of the phone or alternatively do a load check on the battery to make sure it is actually defective, then you are taking a risk.
Of course the value of your time in performing the tests would easily double the effective cost of the new battery.:grumpy:
As far as being aftermarket.
There just isn't that many actual companies that make the stuff compared to the number of brands you find.
For instance at one time there were some 90 odd brands of VCR but only 6 actual production plants.
The company that made the phone would source from a battery company.
It simply is not cost effective for the battery company to set up a separate process to make "aftermarket" batteries. It all comes off the same conveyor belt.
Does that include shipping?.
Hang on. Saving money isn't the big issue. I wouldn't give up a phone that
- I'm used to
- has all my #'s in it
- is compatible with my wife's phone
- is good quality
- etc.
Having a reliable piece of equipment doesn't come free these days.
Anything costing more than a Starbuck's coffee has cheaper knock-offs made of it, why would batteries be any different?
they do vary some BUT most are common cells bought in bulk and put in
a case to fit the phone shape so the cells may be the same as original even in a second party case or better then original or worse
some is luck of the draw as to how long they work
ni-cads get a memory effect if short charged [recharged at 1/2 charged]
they last best if run full cycle max charge to totaly dead
but that's hard to do on a phone
but DONOT charge a more then 1/2 charged battery
or buy 2 and use intill it is dead then switch
Just don't overcharge your cellphones. Its good for the life of the battery.
Way to dredge up an old thread... :)
Um. I presume you meant "it's NOT good"...
I'm with Dave on the old phone thing. Living away from a metro area, I miss my old StarTec that allowed me to manually switch to analog mode. Often it was a much better signal than the digital. Now, 2 phones later I can't even get it to go to analog.
Stand your ground Dave! Buy an aftermarket battery, and if it doesn't work well -- well I am sure you've spent $35 on worse things in your life.
Here you go, Dave. ~$25 gets you a lithium ion battery (no memory effect when charging partially-depleted batteries).
http://www.cellular-blowout.com/ert2tliionba.html
BTW, your phone makes my old Nokia look like it should have a cord on it.
increase battery life?
i don't know if this actually works if you put the battery in the freezer? they say it clears the "memory" and should last longer
Look on ebay. I was going to get a new battery for my old cell phone at one time because it was having the same problem as you. And I think it was actually a better battery. Meaning my old one was say rated at 800mah, while the new was rated at 1200mah. And you could get one for peanuts compared to buying direct from the cell phone manufacturer. Heck for $10 or so you can't go wrong. I understand where your coming from about letting go of your old phone. In fact my new one had exceptionally poor sound quality compared to my old one.
Jim
Replacing the battery on my wifes 2 1/2 year old phone was $35, getting a new phone $40, it took about 5 minutes to transfer the account to the new phone and swap chips. The difference was well worth my time and agravation after having spent an hour running around trying to find a replacement battery in the first place and the additional features were well worth it.
let go
I agree let it go
Yeah. Great. I've got a new phone now.
It's broken. It wants to update my daylight savings every single time it wakes up.
I'm so, so glad I bought a new phone.
What factors affect cell phone battery life?
There are several factors that can affect the battery life of a cell phone, including the age of the battery, the type of phone and operating system, screen brightness, and the number and type of apps that are running in the background.
How can I prolong the battery life of my cell phone?
To prolong the battery life of your cell phone, you can try to limit the number of apps running in the background, reduce screen brightness, and turn off features like location services, Bluetooth, and Wi-Fi when not in use. It is also recommended to use the charger and cable that came with your phone, and avoid using aftermarket chargers.
How long should a cell phone battery last?
The average lifespan of a cell phone battery is around 2-3 years, but this can vary depending on usage and charging habits. It is normal for a battery's capacity to decrease over time, which can result in shorter battery life.
Is it bad to leave my phone charging overnight?
It is generally safe to leave your phone charging overnight, as most modern smartphones have built-in mechanisms to prevent overcharging. However, it is recommended to unplug your phone once it reaches 100% to avoid unnecessary strain on the battery.
Why does my battery drain so quickly?
If your battery is draining quickly, there could be several reasons for this. Some common reasons include having too many apps running in the background, using your phone in areas with poor cell service, and having a weak or old battery. It is also possible that your phone's operating system or certain apps need to be updated to improve battery efficiency.
  • Computing and Technology
  • STEM Career Guidance
12K
  • General Discussion
