Center of mass and Moment of Intertia
To find the center of mass and moment of inertia for the given object, integration is necessary, but triple integration is not required. Instead, using polar coordinates simplifies the process, where you can integrate dm*r and divide by the total mass to find the center of mass. The moment of inertia calculation suggested, which involves using 1/12 of the moment of inertia of a cylinder, is incorrect; the entire mass of the object must be accounted for. Clarification on the definitions of dm and the integration process is needed for a complete understanding. The discussion emphasizes the importance of correctly applying integration techniques to solve for both the center of mass and moment of inertia.
sally21
The thickness of the object is 2 cm. The density of the material (pronounced row) is 7800. The angle (theta) is pi/6. The radius is .75 meters. What is the moment of inertia and
the center of mass?
Here is what the object looks like:
http://www13.zippyshare.com/v/36721619/file.html
The object is rotating around the origin.
None given
Okay, so I have no idea how to find the center of mass for this object. I know you have to use integration, but the other kid in my class was using triple integration (which is something I don't know and I don't know if he was right any way). So I have no idea how to find the center of mass for this object.
As for the moment of inertia, I think that the moment of inertia will be 1/12 of the moment of inertia of a cylinder. I figure this because pi/6 = 30 degrees. 360/30=12. So I think that the moment of inertia will be:
I= 1/2m[(r1^2)+(r2^2)] * 1/12
this is just the moment of inertia formula for a hollow cylinder and I multiplied it by 1/12.
Thank you very much for helping me in any way!
You don't need triple integration. Instead of using x,y,z coordinates, use "r" instead. You can integrate dm*r, then divide the result by the mass to get the r coordinate of the center of mass.
That's not right. Think about it this way: if we fill in the missing 11/12 of the cylinder, the cylinder's mass would be 12m.
Oh thank you!
But, I don't really understand how to find the moment of inertia and now I don't know how to find the center of mass. Can you show me how to find it for this problem? I have no idea what dm is.
bumb
anyone know how to solve this?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
