Proving Magnitude of Position Vector for Centre of Mass
The discussion centers on proving the magnitude of the position vector for the center of mass using the equation M2R2 = M∑ri2 - (1/2)∑mi mjrij2. The user expresses uncertainty about how to approach the problem, starting with the equation F = MR''. They attempt to derive R'' but feel they may be going off track. The response highlights a failure in their LaTeX code, suggesting that reposting the work could facilitate better assistance. Clarity in mathematical representation is crucial for effective problem-solving in this context.
metgt4
Prove that the magnitude R of the position vector for the centre of mass from an arbitrary origin is given by the equation
M2R2 = M\summiri2 - (1/2)\summimjrij2
F = MR''
F = p'
p = \summjrj'
I'm not quite sure where to start with this, but this is what I've tried so far:
F = MR''
R'' = \frac{F}{M} = \frac{p&#039;}{M} = \frac{(\summ<sub>j</sub>r<sub>j</sub>&#039;)&#039;/M<br /> <br /> And that&#039;s about where I think I go wrong. Am I on the right path, or am I waaayyy off?
We cannot see what you have done because your LateX code failed. Try re-posting and someone might be able to help you.
