The center of the galaxy does not intersect the ecliptic but is close to it, specifically near the tip of Scorpio's tail in Sagittarius. This alignment is a temporary coincidence, as the solar system's orbit will shift significantly over time, moving the galactic center away from the ecliptic plane. Currently, the galactic center is approximately 60 degrees south of the ecliptic latitude, making it a southern hemisphere feature. Observers can see the galactic center rising in the southeast around midnight on April 1 and at 10 PM on May 1 in the northern hemisphere. The discussion highlights the orientation of the galaxy relative to the solar system and provides guidance for viewing the galactic center during specific times of the year.
#1
Pjpic
235
Does the center of the galaxy intersect the ecliptic? If so, is it a temporary coincidence?
You may recognize the fishhook curve of bright stars that is Scorpio's tail. It is near the tip of the tail, as I recall.
Scorpio borders on Sagittarius (not as easy to identify) and official sky maps show the galactic center in Sagittarius territory. But it is very close to the tip of that "question mark looking" hook-like curve of scorpion stars.
One quarter of a Galactic Year is what? something like 50 or 60 million years. So solar system will be some 90 degrees around in its orbit and Center will be totally NOT in the plane of the ecliptic.
It will be at around 60 degrees south ecliptic latitude. If you picture the ecliptic south pole? the "down" direction if you visualize planet orbits counterclockwise in a level plane?. then Center will be more close to south ecliptic pole.
Very roughly it will be not so far from the Earth south pole direction. It will be a southern hemisphere feature, not like today.
The plane of the ecliptic, essentially the plane of the solar system, is TILTED BY 60 DEGREES compared with Galactic plane.
Of course both Scorpio and Sagittarius are on the ecliptic (they are "zodiac" constellations).
I guess if you want to view that part of the sky where the Center is, it would be rising at midnight around 1 April.
And two hours earlier (10PM) around 1 May. I'm thinking northern hemisphere, e.g. US latitudes. You would go outdoors say four hours before midnight around 1 June and look just about due Southeast and Scorpio would be rising. Head first as I recall. So a bit later the tail would be completely up over the trees and you could basically point your finger at galactic Center. If you were out away from city lights and it was a dark night you could see the Milkyway all along the Horizon both the east and west of you. The plane of the Galaxy would more or less coincide with your ground plane that you are standing on. (Say if you are around 30 degrees north latitude).
Thats how things are oriented when the Center rises (to the SE) say around 10PM around 1 May. Glad you asked. It reminds me of some nice time in years past.
Partial solar eclipse from Twizel, South Isl., New Zealand ...
almost missed it due to cloud, didnt see max at 0710 NZST as it went back into cloud.
20250922, 0701NZST
Canon 6D II 70-200mm @200mm,
F4, 100th sec, 1600ISO
Makeshift solar filter made out of solar eclipse sunglasses
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed).
n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons.
Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
