Center of Gravity: Does It Have to be Inside Object?
  • Thread starter Thread starter macmac410
    Gravity
The center of gravity does not have to be located within the geometric confines of an object; it can exist outside of it. For a doughnut, the center of gravity is found at the center of the hole, as the mass distribution is symmetrical around that point. This concept illustrates that the center of gravity is determined by the distribution of mass rather than the object's shape. Understanding this principle can clarify confusion regarding the location of the center of gravity in various objects. The discussion emphasizes the importance of mass distribution in determining the center of gravity.
macmac410
1.) Does the center of gravity of an object have to be within geometric confines of the object? Please explain, coz I'm really confuse.
2.)where is the center of gravity of a doughnut? Explain
i don't know the relevant equations
but i can answer it logically, but I'm not sure about my answer. Please help!
The center of gravity is in the hole of the doughnut.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
