Calculating the Central Density Function for a Continuous Random Variable
The discussion centers on calculating the cumulative distribution function (CDF) for a continuous random variable defined by the probability density function (PDF) f(x) = (λ/2)e^{-λ(x-θ)} for x > θ. The initial attempt at integrating the PDF resulted in an incorrect limit leading to infinity, prompting a reevaluation of the lower limit of integration. It was clarified that the lower limit should be θ, as the PDF is zero for x ≤ θ. After correcting the integration limits and notation, the CDF was recalculated, leading to a valid expression. The conversation emphasizes the importance of proper limits in integration for accurate results in probability calculations.
MaxManus
-infinity<x<infinity
x> theta
f(x) = \frac{\lambda}{2}e^{-\lambda (x-\theta)}
F(x) = \int_{-\infty}^x f(x) dx
\int \frac{\lambda}{2}e^{-\lambda (x-\theta)} dx
= -\frac{1}{2}e^{-\lambda(x-\theta)}
Insert the limits:
-\frac{1}{2}e^{-\lambda(x-\theta)} + \frac{1}{2}e^{-\lambda(-\infty-\theta)}
= infinity.
The last part should not be infinity so can anyone see where I go wrong?
You have defined f(x) for x&gt;\theta. Is it zero elsewhere? Should your lower limit be \theta?
Yes it should! Thanks
Insert the limits:
-\frac{1}{2}e^{-\lambda(x-\theta)} + \frac{1}{2}e^{-\lambda(\theta-\theta)}
1/2 -\frac{1}{2}e^{-\lambda(x-\theta)}
You mean e^{-\lambda(\theta- \theta)}, not e^{-\lambda(-\theta- \theta)}
Thanks, corrected it now.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 47 ·
  • · Replies 19 ·
