Central Force Motion: Solve r(t) & theta(t)
roeb
Consider the motion of a particle in the central force F(r) = -kr.
Solve for the particle's location as a function of time, r(t) and theta(t).
E = 1/2 m r'^2 + \frac{L^2}{2mr^2} + U(r)
I know U(r) = 1/2 k r^2
\frac{dr}{dt} = \sqrt{\frac{2}{m}(E-U(r)) - \frac{L^2}{m^2 r^2}}
(Where L is ang. momentum)
Plugging in U(r) I get a really nasty integral
dt = \frac{r^2 dr}{\sqrt{2E/m r^2 - k/m r^4 - L^2/m^2}}
According to my professor I can use a trig sub to solve this, but I am not getting anywhere.
Is there some sort of relationship that I am missing? I know it's supposed to be an ellipse but I seem to get any sort of substitutions to work.
This integral is such a mess.
I think the easiest way is to solve this problem in cartesion coordinates and convert it to polar coordinates.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
