What is the mathematical proportionality for centripetal acceleration?
  • Thread starter Thread starter bayan
    Acceleration
The discussion revolves around determining the mathematical proportionality for centripetal acceleration based on an experimental formula. The initial formula presented is UgM = 4π²rm/T², leading to observations that T is proportional to M^(-0.35), m^(0.53), and r^(0.5). A participant clarifies that T can be expressed as T = Constant * M^(-0.35) * m^(0.53) * r^(0.5), where the constant may depend on other fixed variables. The empirical exponents derived from plotted data suggest a slight discrepancy with the original formula but remain reasonably close. The discussion emphasizes the importance of logarithmic graphs in deducing the constant and understanding the relationships between the variables.
bayan
Hi everyone!
We have been doing a n experiment about Cent acceleration.
We had a formula which was UgM= 4Pie^2rm/T^2
Then we have T being ptoportional to M, R and m
Can someone help me to figure out the proportionality?
It is to be determined using maths although I have got some result (not using maths, only from our observation of graphs and making the LOG graph to find gradiant..) I have got it to be
T proportional to M^-.35
T proportional to m^.53
T proportional to r^.5
Is there anyone that can help me to fing what the mathematical proportionality would be?
Also any work out would be apriciated to explain.
Your plotted data has given you empirical exponents for the dependence of T on each of three variables. I assume your data was collected by allowing only one of the three to vary at any time. When you say "T proportional to M^-.35" You are saying T is some constant times M^-.35, but that constant may depend on the other two variables that you are holding fixed. Similar reasoning appplies to the other two variables. Putting them all together gives you
T = Constant*M^-.35*m^.53*r^.5
The value of the constant can be deduced from the intercepts of logarithmic graphs you plotted.
Your data does not quite agree with your starting formula, but it is not terribly far off.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
