Centripetal acceleration question confirmation please
The centripetal acceleration required to keep a 0.5 kg mass moving at 0.1 m/s in a circular path with a radius of 0.2 m is calculated using the formula a = v^2/r. Substituting the values gives a = 0.1^2/0.2, resulting in an acceleration of 0.05 m/s² directed towards the center of the circle. The calculation appears correct, confirming that the centripetal acceleration is indeed 0.05 m/s². There is some uncertainty expressed about the result, but the math checks out. This confirms the necessary centripetal acceleration for the given parameters.
pinnacleprouk
what is the magnitude and direction of the centripetal acceleration necessary to confine the motion of a 0.5kg mass moving at speed 0.1m/s to a circular path 0.2m in radius
a = v^2/r
0.1^2/0.2 = a
a = 0.05m/s/s towards the centre
Doesn't look right to me
Thanks in advance
Doesn't sound unreasonable
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
