Centripetal Force: Why Don't Planets Fall from Sun?
Centripetal force is essential for keeping planets in orbit around the Sun, as it is provided by gravitational attraction rather than direct manipulation like spinning a cup on a string. Unlike the cup, which requires continuous force to maintain its motion due to air resistance, planets move in a vacuum where such resistance is absent. The Sun's gravitational pull creates a curvature in spacetime, allowing planets to maintain their orbits without needing external force adjustments. The discussion highlights the difference between applied forces in a mechanical system and gravitational forces in celestial mechanics. Understanding these concepts is crucial for grasping the dynamics of planetary motion.
Quincy
Suppose if you're spinning a thread by your finger that has a cup attached to it at the other end. You would need to keep wobbling your finger or the cup would stop spinning, right? Then why doesn't the Sun wobble to keep the planets spinning around it? Or does the cup stop spinning because of the downward gravitation force?
I still haven't finished high school so i might be wrong, so here goes :) ...
when you wobble your fingers, i think you might be applying the tension which acts as the centripetal. The tension would be equivalent to the gravitational pull of the sun towards the earth. In addition to that, the Earth is moving at a constant speed (though i think its slowing down?), While the cup face frictional forces like air resistance, so tangentially its decreasing some of the force you apply by your fingers, most proabably also causes some sort of tangential acceleration too.
Please if I'm wrong correct me, I will be having a quiz on this topic, which me luck :D
thanks,
lol same here.
I forgot about air resistance; so I guess if you spin the cup in outer space, it will keep on spinning without having to wobble your finger.
The sun keeps the planets in place via gravitational attraction...the curvature of spacetime.
Your finger has no gravitational attraction to a cup...at least it's negligible...you move the cup via the string via directly applied force...you apply centrifugal force to the cup; centripetal force holds in for accelerating from you...not gravity...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
9K
