What Factors Influence Centripetal Motion and Acceleration?
Centripetal motion involves constant speed but changing acceleration due to directional changes, which affects velocity. Key factors influencing this motion include the mass of the object, the radius of the circular path, and the centripetal force, calculated as F = (m*v^2)/r. The frequency of cycles impacts tension in a string during circular motion, with relationships between mass and frequency also being significant. In non-uniform circular motion, tangential acceleration adds complexity to the overall acceleration, which can be calculated using vector components. Understanding these principles is essential for grasping the dynamics of centripetal motion and acceleration.
dekoi
Would anyone be kind enough to explain the concept of centripetal (circular) motion to me?
How accelerations are determined (i understand they are non constant);
What factors affect this motion, and/or what factors relate to it.
How do limits relate to this type of acceleration?
Thank you.
I understand the concept of this sort of acceleration. The speed remains constant throughout the cycles, however, the acceleration changes due tot he change in direction -- and thus a change in velocity.
Howevever, i am not sure how frequency of the cycles affects e.g. tension (of a string, if a string is spinning with an attached rubber stopper for example), how mass affects frequency, and other relationships with frequency.
Sounds like a direct homework question from the text :rolleyes:
Try giving it a try and I'm sure you can find all the answers on google
It is not a direct homework question. Although I'm glad you feel my sentence structure seems like it :)
Circular motion is characterized by an orbital radius r, a speed v, the mass m of the object which moves in a circle, and the magnitude F of the centripetal force. The force of the Centripetal motion equals (m*v^2)/r
velocity=2*pi*R/T
acceleration=v^2/R
angular frequency= 2pi/T
T is the period
velocity=2*pi*R/T
acceleration=v^2/R
T is the period
That's assuming uniform circular motion where the only acceleration is towards the center of the circle.
In non-uniform circular motion (where the speed of the object is accelerating) there is also a tangental component of acceleration that is tangent to the circle of motion. You can then take the vector product of the tangential and centripital acceleration to get the net acceleration.
dekoi said:
<snip>
</snip>
Not quite. For your more simple cases, the speed is constant, but the direction is changing, and as a result the velocity is changing, so the object is accelerating.
The acceleration is NOT changing!
For more complex cases (as previously stated by dav2008) you can have a non-uniform acceleration, but I thought this needed clarifying first.
