Chadwick's experiment and proton velocity
Chadwick measured proton velocity in the polonium-beryllium experiment by likely accelerating protons through a voltage, using the relationship K=qV to determine kinetic energy. The charge of the protons and the applied voltage allowed for calculations of their drift velocity. Additionally, the deflection of particles in a magnetic field could be analyzed using the Lorentz force equation, F=qvB*sin(x). While the exact methods are debated, the principles of voltage acceleration and magnetic deflection are central to understanding proton behavior in this experiment. Overall, the discussion highlights the complexities in accurately measuring proton velocity in nuclear experiments.
Ferrus
How did he measue the proton velocity in the polonium-beryllium experiment? The only source with some description describes his using current as a means to do so - but sure that would require knowledge of the number of protons in order to ascertain the drift velocity?
I Read a little about the experiment . He may have accelerated the protons through a voltage. K=qV k= kinetic energy q=charge V=voltage . And then he could have deflected the particles in a magnetic field
using the Lorentz force . F=qvB*sin(x)
Not sure about the Lorentz force but accelerating them through a voltage would be reasonable.
Not sure though .
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
