We define a complex analytic function
<br />
f(z) = \frac{z^3\log^2(z)}{1 + z^6}<br />
and aim for the summit!
By using the L'Hopital's rule results mentioned above, we see that the integrals over the sets I_{2,R} and I_{4,\epsilon} converge to zero just like for the previous function too. The square of the logarithm has sufficiently similar asymptotics to the logarithm itself.
The formula
<br />
\int\limits_{I_{1,\epsilon,R}}f(z)dz = \int\limits_{\epsilon}^R\frac{x^3\log^2(x)}{1+x^6}dx<br />
is obvious again. On the line I_{3,\epsilon,R} the integral is not so obvious:
<br />
\int\limits_{I_{3,\epsilon,R}}f(z)dz = e^{\frac{\pi i}{3}}\int\limits_{\epsilon}^R \frac{x^3\big(\log^2(x) + \frac{2\pi i}{3}\log(x)- \frac{\pi^2}{9}\big)}{1 + x^6}dx<br />
The integral over the whole contour is therefore
<br />
\int\limits_{\gamma}f(z)dz = \Big(1 + e^{\frac{\pi i}{3}}\Big)\int\limits_{\epsilon}^R \frac{x^3\log^2(x)}{1+x^6}dx + \frac{2\pi i}{3}e^{\frac{\pi i}{3}}\int\limits_{\epsilon}^R\frac{x^3\log(x)}{1+x^6}dx- \frac{\pi^2}{9}e^{\frac{\pi i}{3}}\int\limits_{\epsilon}^R \frac{x^3}{1+x^6}dx + o(1)<br />
On the other hand in the limit z\to e^{\frac{\pi i}{6}} the function has the form
<br />
f(z) = \frac{e^{-\frac{5\pi i}{6}}}{6} \frac{(e^{\frac{\pi i}{6}})^3 (\frac{\pi i}{6})^2}{z- e^{\frac{\pi i}{6}}} + O(1)<br />
and by the residue theorem the value of the integral for 0<\epsilon < 1 < R is
<br />
2\pi i \frac{e^{-\frac{5\pi i}{6}}}{6} \big(e^{\frac{\pi i}{6}}\big)^3 \big(\frac{\pi i}{6}\big)^2 = -\frac{\pi^3}{4\cdot 27} e^{\frac{\pi i}{6}}<br />
By writing the two expressions for the integral as equal, taking the limits \epsilon\to 0 and R\to\infty, and using the integral formulas proven above, we get
<br />
-\frac{\pi^3}{4\cdot 27}e^{\frac{\pi i}{6}} = \Big(1 + e^{\frac{\pi i}{3}}\Big)\int\limits_0^{\infty}\frac{x^3\log^2(x)}{1+x^6}dx + \frac{2\pi i}{3}e^{\frac{\pi i}{3}}\frac{\pi^2}{54} - \frac{\pi^2}{9}e^{\frac{\pi i}{3}}\frac{\pi}{3\sqrt{3}}<br />
"So close, so far..."
We multiply both sides by e^{-\frac{\pi i}{6}} and simplify:
<br />
-\frac{\pi^3}{4\cdot 27} = \sqrt{3}\int\limits_0^{\infty}\frac{x^3\log^2(x)}{1+x^6}dx + \frac{\pi^3}{3\cdot 27} e^{\frac{2\pi i}{3}} - \frac{\pi^3}{27\sqrt{3}}e^{\frac{\pi i}{6}}<br />
We substitute
<br />
e^{\frac{2\pi i}{3}} = -\frac{1}{2} + \frac{i\sqrt{3}}{2}<br />
and
<br />
e^{\frac{\pi i}{6}} = \frac{\sqrt{3}}{2}+ \frac{i}{2}<br />
The imaginary terms cancel and we are left with
<br />
-\frac{\pi^3}{4\cdot 27} = \sqrt{3}\int\limits_0^{\infty} \frac{x^3\log^2(x)}{1+x^6}dx - \frac{\pi^3}{2\cdot 3^4} - \frac{\pi^3}{2\cdot 3^3}<br />
We can solve the integral expression and it turns out to be
<br />
\int\limits_0^{\infty}\frac{x^3\log^2(x)}{1+x^6}dx = \frac{\pi^3}{2\cdot 3^3\sqrt{3}}\Big(\frac{1}{3} + 1 -\frac{1}{2}\Big) = \frac{5\pi^3}{2^2\cdot 3^4\sqrt{3}} = \frac{5\pi^3}{324\sqrt{3}}<br />
It is difficult to go through all this without making mistakes, but little aid comes from the fact that mistakes usually result in an integral of some real valued function having an imaginary component. So eventually fixing the mistakes is not impossible.
micromass said:
Please list any sources that you have used to solve this question.
My list consists of only Funktioteoria I-II by Olli Lehto. I didn't remember how these 2\pi i things went in the residue theorem, since I had not used complex integration for anything for years, and I had to check them from somewhere.
