Convert Frequency: 15Hz to USA/Indo-Pak
  • Thread starter Thread starter otomanb
    Change Frequency
In Indo-Pak, the standard power supply frequency is 50Hz, while in the USA it is 60Hz, leading to inquiries about converting frequencies to specific values like 15Hz. Solutions include using a motor-generator combination or employing a variable frequency inverter, which can generate a range of frequencies, typically from 0 to 120Hz. The discussion highlights that while 15Hz can be achieved, it may not be ideal for power applications due to potential inefficiencies. Additionally, dielectric heating techniques utilize high frequencies (10 to 30MHz) for specific heating applications, showcasing the versatility of frequency manipulation. Overall, various methods exist for frequency conversion, each with its own applications and limitations.
otomanb
As we know in indo-pak our home supply voltages frequency is 50 Hz. And in USA it's 60Hz. Is there any device/circuit that can change frequency to 15Hz or any other according to our requirements.
Please Elaborate :confused:
You can use a motor-generator combination, or rectify the input power and use an inverter to make your new output power waveform.
Quiz Question -- why would 15Hz be a bad choice for a power waveform?
How much power? You could mix and filter. That would be way cool (in a Rube Goldberg sort of way) -- a Power Mixer! :approve:
here is an example in "Dielectric heating" which is used to heat insulators like wood, plastic, ceramics etc which cannot be heated easily and uniformly by another method.
In this method we apply voltages of about 20KV at frequency of 10 to 30Mhz. Now how they change frequency. One method may be changing the speed of generator but any other one!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
