Is the speed of light affected by relative motion?
paras02
Hello!
if a car(A) is moving with a speed 2m/s and another car(B) is moving in opposite direction with speed 3m/s. then velocity of car(A) with respect to (B) is 5 or -5m/s .
so my question is why the same principle does not follow with speed of light as according to theory of relativity speed of light remains same from every frame of refrence ?
or i can say that if i move with a speed c/2( c is the velocity of light ) opposite to the direction in which light is propogating the velocity of light w.r.t me will be 3v/2 or -3v/2.
Isn't this true?
Simply put - that's not the way our universe works. Feynman said, "You don't like it? Go somewhere else!"
paras02 said:
Hello!
Isn't this true?
Actually, the law is the same :smile:. It's only that you didn't know which is it:
V = (v1 + v2)/(1 + v1*v2/c2).
Now put 2m/s as v1 and 5m/s as v2 and compute V.
Then do the same with v1 or v2 or both, equal to c = 299,792,458 m/s.
lightarrow
thankyou guys
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
