Has Anyone Invented a Way to Change the Orientation of Force Without a Fulcrum?
  • Thread starter Thread starter dE_logics
    Force
The discussion explores the concept of converting an applied force to a 90-degree angle without using a separate body, such as a fulcrum, which typically introduces reluctance to motion. It compares this idea to a seesaw, where the fulcrum is essential for force transfer but also creates resistance. The conversation suggests the possibility of using a fluid system, where pressure applied to the fluid could generate a normal reaction, potentially functioning like a spring. The feasibility of such an arrangement remains uncertain, prompting further contemplation on innovative mechanical designs. Overall, the inquiry seeks alternatives to traditional force deviation methods that minimize resistance.
dE_logics
Till now...has anyone made such an arrangement that converts an applied force to 90+ degrees completely without use of any separate body which causes reluctance to motion?
I mean take a see saw arrangement...if force applies on one side, the force is transferred to the other side (or deviated by 180 deg), but via another body which acts as a fulcrum.
In the above case the fulcrum is the separate body which causes reluctance to motion.
So till now...has anyone made such an arrangement such that it can deviate the force without use of such a fulcrum as in the seesaw arrangement?
would a brake work? I mean a fluid acting as your object.
The thing providing pressure to the fluid will cause the body to give a normal reaction.
Its like a spring actually.
Pondered on that before :smile:
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
