Charge densities and delta functions
16 replies · 4K views
spaghetti3451
Note from mentor: this thread was originally posted in a non-homework forum, therefore it lacks the homework template.
I was wondering if the electric charge density ##\rho({\bf{r}})## of a point charge ##q## at position ##{\bf{r}}_{0}## is given by ##\rho({\bf{r}})=q\delta^{(3)}({\bf{r}}-{\bf{r}}_{0})##.
If so, is this because ##\int d^{3}{\bf{r}}\ \rho({\bf{r}}) = \int d^{3}{\bf{r}}\ q\delta^{(3)}({\bf{r}}-{\bf{r}}_{0}) = q##?
If it's a point charge at rest, yes. Note that ##\delta^{(3)}(\vec{r}-\vec{r}_0)## is NOT a function BUT a distribution (generalized function)!
Let's say that now we have a point charge ##-q## at the origin and a point charge ##+q## at position ##\bf{r}_{0}##. Is the charge density of the dipole given by ##\rho({\bf{r}})=-q\delta^{(3)}({\bf{r}})+q\delta^{(3)}({\bf{r}-\bf{r}_{0}})##?
Yes, but usually a dipole is defined as the approximation that ##r_0## is very small in the sense of the multipole expansion.
Thanks.
I'm also trying to find the charge density of a uniform infinitesimally thin spherical shell of radius ##R## and total charge ##Q## centred at the origin.
This is my attempt:
##\int\ \rho({\bf{r}})\ dV = Q##
##\lim\limits_{\epsilon\to 0}\ \int\limits_{R-\epsilon}^{R+\epsilon}\ \rho({\bf{r}})\ (\text{sin}\theta\ d\theta\ d\phi)\ (r^{2}dr) = Q##
##\lim\limits_{\epsilon\to 0}\ \int\limits_{R-\epsilon}^{R+\epsilon}\ \rho({\bf{r}})\ (r^{2}dr) = \frac{Q}{4\pi}##
Any hints on what to do next?
failexam said:
Thanks.
This is my attempt:
How about assuming ρ(r) = f(r) δ(r - r0) in your last integral
because you know ρ will have to have an infinity at r0 to cancel out the dr in Q = ∫ρ(r) dV = ∫ρ(r) 4π r2 dr
then putting that in your last integral and solving for f(r0) and stating f(r) = f(r0) with r0 = r.
PS I used r0 in lieu of your R.
Sorry
What is the reason for ρ should have an infinity at r?
garylau said:
Sorry
ρ is infinite at r0.
It's because the shell of charge is modeled as having zero thickness. Since the shell contains a finite amount of charge, the density of charge must be infinite.
It's somewhat similar to a point charge. If a finite amount of charge occupies a single point, then the density of charge must be infinite.
Do you mean the volume is zero So the Q/volume=infinity?
Yes, the volume is zero. So the volume charge density ρ is infinite. The surface charge density is finite.
i See thank you
You are welcome. I'm glad I could help.
there are one more question
How to use ρ at infinity to cancel out the dr in Q??
can you explain more
thank
thank
I'm not sure I understand the question. The idea is that ρ(r) is zero everywhere except where r = R. (I'm switching the notation from r0 to R for the radius of the spherical shell in order to conform to post # 5. Sorry for the notational confusion.) At r = R, ρ is infinite.
So, assume that ρ(r) is proportional to δ(r - R): ρ(r) = Cδ(r - R).
You just need to determine C. Do this by requiring ∫ρ(r)dV = Q for integration over all space. Express the integral in spherical coordinates and work out the value of C.
it look likes the C should be the surface charge density
Yes, that's right.
Usually a dipole is formed as a limit as separation d->0 but with charge q/d to compensate.
