Integrate and Evaluate Vector Functions | Circle and Straight Line Paths
  • Thread starter Thread starter thenewbosco
    Integral
The discussion focuses on evaluating vector integrals along specific paths. The first integral, a closed integral around a circle, was incorrectly calculated as 2πa; the correct result is zero since the sum of vectors in a closed path yields the null vector. For the second integral, the evaluations along both the straight line and the segmented path resulted in 3/2, which is likely correct due to the conservative nature of the vector field. The importance of parameterization in vector integrals is emphasized, particularly for closed paths. Overall, the evaluations highlight key concepts in vector calculus, including path independence and the significance of vector summation.
thenewbosco
hello, i just wish to check that i have done the following correctly:
1. Evaluate \int d\overarrow{r} (r is a vector, and its a closed integral) around the circle C represented by x^2 + y^2 = a^2
what i did here was switch to polars and called d\overarrow{r} ->rd\theta then i noted that r=a and integrated from 0 to 2pi to get the answer as 2pi * a.
and
2. If \overarrow{f} = x\hat{x} + y\hat{y} + z\hat{z}
evaluate \int \overarrow{f} \cdot d\overarrow{r} from (0,0,0) to (1,1,1) along
a) a straight line connecting these points
b) a path from (0,0,0) to (1,0,0) to (1,1,0) to (1,1,1)
for both of these i ended up getting 3/2
for a i just replaced y and z by x and dy and dz by dx and integrated 3x dx...
and for b i got 3/2 by adding up three integrals so i think this should be correct? thanks
You should have gotten a hint that your answer is incorect for 1. since what this integral represents is the adding of many many tiny vectors one at the end of another such that the last one of these tiny vector ends where the first one started. Such a sum of vector gives the null vector. (Not to mention that you're summing vectors but your answer is a scalar )
What \oint d\vec{r} represents is actually
\int_{t_1}^{t_2}\frac{d\vec{r}}{dt}dt
for some parametetrisation \vec{r}(t), t\in (t_1,t_2)[/tex] of the circle. So, what this comes down to is finding a parametrisation of the circle and integrate its derivative.<br /> <br /> For 2. there is a good chance that is correct since \nabla \times \vec{f}=0, i.e. the field is conservative, so the line integral should be path-independant.
However, if you had to integrate
\oint_C ||d\vec{r}||
then this would have been 2\pi a since now you're adding the length of all the tiny vectors, which in the limit dr-->0, should give you the circumference of the circle.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
