How to Verify the 5th Term of the Binomial Expansion of (3-2/x)^9?
  • Thread starter Thread starter donniemateno
    Binomial Series
To verify the 5th term of the binomial expansion of (3-2/x)^9, the general term formula is applied: T(r+1) = n!/(n-r)!r! * A^(n-r) * B^r. For this case, r is set to 4, A is 3, B is -2/x, and n is 9. The calculated term results in -489888/x^4. To check the answer, one should ensure the correct application of the formula and confirm the sign of each component in the expansion.
donniemateno
hi there I am abit stuck here. i got a q saying :
in binomial expansion of (3-2/x)^9 find the 5th term using the general term of the binomial expansion and check your answer
(3-2/x)^9
used formula
=N!/(n-r)!r! * A^(n-r) * b ^ r
r= 4
a= 3
b= - 2/x
n=9
got a answer of -489888/x^4
How do i go about checking my answer??
My answer is like yours, but without the negative sign.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
