How to Integrate Complex Vectors Using the Vector Triple-Cross-Product Formula?
In summary, the conversation discusses the integration of a vector expression and arrives at a solution using the vector triple-cross-product formula.
Ceres629
[tex]
\int [a(\dot{b}\cdot a + b\cdot\dot{a}) + \dot{a}(b\cdot a) - 2(\dot{a}\cdot a)b - \dot{b}|a|^2]\, dt
[/tex]
The above are all vectors. How would one go about integrating this, the answer is apparently
[tex]
a \times (a \times b) + h
[/tex]
where h is a constant vector
I don't quite see how they arrive at this answer...
p x (q x r) = q(p.r) - r(p.q)
Ceres629 said:
[tex]a \times (a \times b) + h[/tex]
Hi Ceres629! :smile:
Easy-peasy … use the standard vector triple-cross-product formula:
p x (q x r) = q(p.r) - r(p.q), and then differentiate carefully! :smile:
1. What is the definition of the integral of a vector expression?
The integral of a vector expression is a mathematical operation that calculates the area under the curve of a vector function. It can also be interpreted as finding the displacement or change in position of a moving object.
2. How is the integral of a vector expression calculated?
The integral of a vector expression is calculated by finding the antiderivative of the vector function and evaluating it at the upper and lower limits of integration. This can be done using various techniques such as substitution, integration by parts, or using specialized formulas for specific vector functions.
3. What are the applications of the integral of a vector expression?
The integral of a vector expression has many real-life applications, such as calculating work done by a force on an object, finding the center of mass of a system, and determining the displacement of a moving object. It is also used in fields such as physics, engineering, and economics.
4. Can the integral of a vector expression be negative?
Yes, the integral of a vector expression can be negative. This occurs when the curve of the vector function lies below the x-axis. In this case, the area under the curve is considered negative, and the integral will have a negative value.
5. Are there any special cases when calculating the integral of a vector expression?
Yes, there are special cases when calculating the integral of a vector expression. For example, when the vector function is discontinuous or has sharp corners, the integral may not exist. In such cases, specialized techniques such as line integrals or surface integrals may be used instead.
  • Calculus
  • Linear and Abstract Algebra
