Chemical equation simplification
  • Thread starter Thread starter Integral0
    Chemical
The discussion centers around balancing chemical equations, specifically the reaction 4CO + 2O2 -> 4CO2. The initial confusion arises from an attempt to simplify this equation incorrectly. It is clarified that the correct simplification results in 2CO + O2 -> 2CO2, which is balanced. The error identified involves mixing up the representation of oxygen (O vs. O2) and misunderstanding how to simplify the equation properly. The correct approach to simplification is emphasized, noting that dividing the number of moles of O2 by two would lead to a fraction, which complicates the equation unnecessarily. The key takeaway is that the original equation is balanced, and the simplification process must be handled carefully to avoid errors.
Integral0
4CO + 2CO2 -> 4CO2 this is Balanced
when I simplify, the simplification doesn't work
2CO + O2 -> 2CO2
3 moles of O2 does not equal 4 Moles of O2
where's my error?
Chemistry news on Phys.org
2CO + O2 -> 2CO2
where's my error?
I assume your initial reaction was supposed to be:
4CO + 2O2 -> 4CO2 otherwise it didn't start out balanced
In the simplified form, the error is you're mixing up O and O2. Just count O and you get this:
Left side
2 CO = 2C + 2O
1 O2 = 0C + 2O
Total= 2C + 4O
Right side
2 CO2 = 2C + 4O which is the same as the total for the left side.
RE
actually this is the reaction I meant
CO + O2 -> CO2 (Unbalanced)
sorry it was a mistake originally
Okay, then look carefully at the original equation.
4CO + 2O2 -> 4CO2
To simplify the equation, you divide by two. This gives you:
2CO + O2 -> 2CO2
This is what you had in your first post as the solution, and it was a correctly balanced equation. You can't simplify any further since you're already down to just one O2 on the left side of the equation. The unbalanced equation you're having trouble with doesn't take into account dividing 1 O2 by 2, which would give you 1/2 O2. This wouldn't be wrong, but it's not any simpler when you start adding fractions, so you stop simplifying before you get to fractions.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
