Chemical Equilibria: Law of Mass Action & Beyond
The discussion centers on the chemical equilibrium law and its relationship with the law of mass action. The fundamental principle states that the rate of the forward reaction equals the rate of the backward reaction, which is foundational for understanding equilibrium. However, the law of mass action does not always accurately predict reaction rates, leading to questions about its applicability. Participants highlight that the rate of a reaction is typically dependent on the concentration of reactants raised to their stoichiometric coefficients, but this can be misleading in complex reactions. For example, the reaction between hydrogen and chlorine to form hydrogen chloride is not straightforward and involves multiple elementary steps, indicating that the overall stoichiometric equation may not reflect the actual reaction mechanism. This complexity suggests that understanding the reaction mechanism is crucial before applying the law of equilibrium, as many reactions do not adhere strictly to the stoichiometric relationships outlined by the law of mass action.
sadhu
chemical equilibrium law is made using the fundamental rule
rate of forward reaction=rate of backward reaction
and then applied law of mass action to it
but law of mass action is not always correct in giving relation for the rate .
so why it is used there?
secondly if equilibrium depend upon the stoichiometric representation of reaction , then how can one tell which one will give correct relation ,or is it that all are correct?/
thanks in advance!
Chemistry news on Phys.org
thanks in advance!
The rate of reaction is usually a function of concentration of one or more of the reagents. You see this also applied in equilibrium discussion... of course the explanation is that the rate of forward and reverse reactions are equal in those explanations.
Are you sure you understand the law of mass action?
I think i am
well is it not this ,that rate of a chemical reaction is directly proportional to the active masses of the reactant raised to the power of their stoichiometric coefficients "
or else I slept whole year... :-(
sadhu said:
I think i am
Substitute 'concentration' for 'active masses' and I think you are close.
Do you think that is not the case that the rate of a chemical reaction is directly proportional to the concentration of one or more of the reactants raised to its stoichiometric coefficient?
right
but
what about the rate of reaction H2 +Cl2=>2HCl
it should be
rate=k
[Cl2]
but somewhere i studied that it is a zero order reaction i.e rate is constant irrespective of concentration of reactants
Complex reactions
sadhu said:
right but
what about the rate of reaction H2 +Cl2=>2HCl? It should be
rate=k
[Cl2]
No. The reaction does not go as written in the equation, which is merely a summary of the overall reaction. The reactions of H2 with halogens are
complex chain reactions involving several elementary steps:
Br2 + M \leftarrow \rightarrow M + 2Br
Br + H2 \leftarrow \rightarrow HBr + H
H + Br2 \rightarrow HBr + Br.
In such cases, you cannot expect the law of mass action based on the overall reaction to work. For a discussion of this type of reaction, look in "The Foundations of Chemical Kinetics" by Sidney W. Benson (1960) or in a more
modern kinetics book.
that means i need to know the mechanism before applying the law of equilibrium
none of the books i have got mention anything regarding finding mechanism before applying law of equilibrium to reactions they only tell that in kinetics part.
unless a single stage reaction
because all reactants are "reacted" within one step: that step is called rate-determining step.
for most of reactions, you cannot expect that the rate of reaction has any relationship with the stoichoimetric coefficients of all reactants or products...and the order of reaction with respect to the reactants/products are as well...
