Solve Equilibrium for Chemical Reaction: 2A <-> B + C
The discussion revolves around solving the equilibrium concentrations for the reaction 2A <-> B + C, given initial concentrations and an equilibrium constant (Keq = 2.03). The initial concentrations are [A]o = 0.2150 M and [B]o = [C]o = 0.4150 M. The user is attempting to set up the equilibrium expression but is struggling with rearranging the equation and solving for the variable x using the quadratic formula. The correct approach involves substituting the equilibrium concentrations into the Keq expression and simplifying it to the standard quadratic form. The discussion emphasizes the importance of correctly applying algebraic manipulation to find the equilibrium concentrations and the Gibbs free energy change (deltaG) at 25°C.
Hollysmoke
The following reaction initially contains [A]o = 0.2150 M and o = [C]o = 0.4150 M. If the equilibrium constant for the reaction is Keq = 2.03, what are the concentrations of reactants and products when the reaction has achieved equilibrium? What is the value of deltaG for the reaction at 25oC?
2 A <-> B + C
I am stuck as on how to proceed with the math. I'm not sure if I am doing it correctly or not. Could someone please take a look?
Initial: 2A B C
0.2150M 0.4150M 0.4150M
Change: +x -x -x
Since Q>Kc, as Qc = [C]/[A]^2
Equil. 0.2150+x 0.4150-x 0.4150-x
I'm stuck on the whole rearranging and solving for x bit. I know I'm supposed to use quadratic formula.
Substitute the values you know for the equilibrium concentration of A, B and C (A=0.2150+x, B=0.4150-x, C=0.4150-x) into the expression for equilibrium and solve it.
Keq=2.03=[(0.4150-x)^2/(0.2150+x)^2] and expand it out, multiply both sides by (A+x)^2, do the algebra until the expression for Keq is in the form:
0 = ax^2 + bx + c (note that here the terms a, b and c are not the same as A, B and C given in the problem)
Hint: The first step should look like this:
2.03*(0.2150+x)^2 = (0.4150-x)^2, after multiplying both sides by (0.2150+x)^2
