Chemistry - acids, bases, equilibrium
To compute the pH of a neutral aqueous solution at a temperature where Kw is 3.49e-13, the equation Kw = [H+][OH-] is applied. Assuming [H+] equals [OH-] in a neutral solution, the concentration of hydrogen ions is calculated as [H+] = 3.49e-6. The pH is then determined using the formula pH = -log[H+], resulting in a pH of approximately 5.457. The discussion emphasizes the relationship between Kw and pH, highlighting that Kw varies with temperature. Understanding these concepts is crucial for solving equilibrium problems in chemistry.
ArcadianGenesis
Like all equilibrium constants, Kw varies somewhat with temperature. Given that Kw is 3.49e-13 at some temperature, compute the pH of a neutral aqueous solution at that temperature.
Kw = [H+][OH-]
pH = -log[H+]
3.49e-13 = [H+]*10e-7
[H+] = 3.49e-6
pH = 5.457
remember Kw is the ionproduct of water at a given temperature. So {H+}*{OH-}= 3.49e-13 next {H+}*{OH-} can be seen as {H+}e2 so what to do next to gain {H+} from Kw?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
