Chemitrails/Contrail and factors
  • Thread starter Thread starter Numeriprimi
    Factors
Chemtrails are often confused with contrails, which are condensation trails formed by aircraft at altitudes of 8-12 km. These trails result from water vapor produced during fuel combustion, which condenses into ice crystals under certain atmospheric conditions. Factors such as humidity, temperature, and aircraft speed influence the formation, shape, and persistence of contrails. Scientific evidence supports that contrails are primarily water vapor, not harmful chemicals as suggested by chemtrail conspiracy theories. Understanding the physics of contrail formation can help clarify misconceptions about their nature.
Numeriprimi
Do you know chemtrails? http://en.wikipedia.org/wiki/Chemtrail_conspiracy_theory
I want know more about it! Please, help me.
I want scientifically prove it is condensing lines to my friends.
I know this is just condensation lines for aircraft. However, how do I prove them? Is there any information that is inconsistent with the fact that it chemtrails really are?
The aircraft must be 8-12 km above the ground for the formation of condensation lines. However, sometimes condensation lines don't incur... Dependence on atmosphere, humidity, speed ... And what do you know you about it? What factors depends on the shape and length of the condensing lines? And how?
And now a little physics ... How can we calculate the length of the condensate lines?
(sorry for my English, if you don't understand me, write, I will try to write it better)
http://science-edu.larc.nasa.gov/contrail-edu/faq.html
These trails are basically water vapor that gets condensed. Some simple estimates...
Kerosene is basically n-decane. When it gets burned you get:
C_{10}H_{22} + 15\frac{1}{2}O_2 \rightarrow 11H_2O + 10CO_2
A 747 consumes about 10 kg of fuel per km.
You see from the combustion reaction that for each mole of fuel, it produces 11 moles of water (and 10 moles of CO2).
So 10 kg of fuel produces almost 14 kg of water. This water is in the gas phase at first, so it occupies a lot of volume.
A cirrus cloud contains about 0.03 grams of liquid water per cubic meter of air.
So if all the water produced during a 1 km flight would produce the same liquid water density as a cumulus cloud, the water vapor would occupy about 14000/0.03=460,700 cubic meters of air. Spread out over a cylinder of 1 km, the diameter of the cylinder would be 25 meters.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
