Choose Parts for an 18000BTU/h Refrigeration Cycle: Who Sets the Temperature?
  • Thread starter Thread starter eaboujaoudeh
    Refrigeration
The discussion revolves around the design of a refrigeration cycle, specifically for an 18000 BTU/h system. Participants explore the factors influencing the selection of components such as the compressor, thermal expansion valve, evaporator, and condenser, and how these components relate to the operating temperatures of the cycle.
  • One participant questions who determines the liquid and evaporating temperatures in the refrigeration cycle design.
  • Another participant suggests that the characteristics of the operating fluid primarily dictate the liquid and gas phase temperatures, indicating that design implementation affects operational temperatures.
  • A different participant expresses uncertainty about refrigeration principles and suggests the need for clarification on the original question.
  • A further contribution mentions R-22 as an example and seeks to understand what ensures that the system operates at specific condensing and evaporating temperatures.
Participants do not appear to reach a consensus on the mechanisms that set the operating temperatures in a refrigeration cycle, with multiple viewpoints and questions remaining unresolved.
There are limitations in the discussion regarding the assumptions made about the operating fluid and the specific design choices that influence temperature settings. The participants have not fully explored the dependencies on definitions related to refrigeration cycles.
eaboujaoudeh
Hey All
Suppose ur designing a refrigeration cycle. if u go to the market to choose parts for an 18000BTU/h circuit. The compressor has different ratings according to the entering temp and exit temp, then u have the thermal expansion valve which is also rated in BTU/hr depending on entry and exit pressures, the Evaporator and condenser are also rated according to the BTU/h scale depending on the evaporating and condensing temperatures..
my question is, who sets the liquid and evaporating temperatures?
how could i be sure that my cycle would be a high temperature cycle? or medium, or low temperature!
Sounds like a job for the Russman.
1) The liquid and gas phase temps are primarily determined by the characteristics of the operating fluid.
How you implement those characteristics into your design sets the operational temps.
2) I don't know a lot about refrigeration, but I think you need to clarify this question.
using R-22 for example...what my question means is that to design a refrigeration cycle u select the pieces according to capacity, but what makes sure they wil operate at a certain condensing temp and evap and not another?
  • · Replies 30 ·
  • · Replies 17 ·
24K
