Choosing Integrating constants for Electric Field
The discussion revolves around calculating the electric field at a point along the axis of a nonconducting disk with a uniform positive surface charge density. The correct approach involves integrating the electric field contributions from infinitesimal rings of charge, specifically from 0 to R, rather than from -R to R. This is because the integration is performed radially outward from the center of the disk, where the positive radius is defined. Participants clarify terminology, noting that "interval of integration" is the appropriate term rather than "integrating constants." The conversation concludes with a mutual understanding of the integration process and its relevance to exam preparation.
Jen2114
A nonconducting disk of radius R has a uniform positive surface charge density sigma. Find the Electric field at a point along the axis of the disk at a distance x from its center. Assume that x is positive
E=kq/r
I know I'm suppose to find dEX for one ring and then integrate to find the field due to all the rings.
dEx= (k) (2πσrx)dr /(x^2 +r^2) ^3/2
Why should you integrate this component from 0 to R and not R to -R
Where exactly is the part of the disk from r=0 to r=-R? That is, where are the negative radius locations?
By the way, it is not an integrating constant as you suggest in the title. This is a definite integral so there is no integrating constant.
For any future reference,what you mean is called "interval of integration" and not constants.
Likes DEvens
Hi,
sorry you're right I should've said that I don't understand why the limits of integration are 0 to R and not -R to R. The center of the disk is located at (0,0) and so the negative radius is at (0,-R) and the positive is at (0,R). The radius of the first ring I'm integrating is r and so then I have to integrate for the entire disk.
Thank you, I will be much more clear next time
Think about it logically.You are integrating radially outwards from 0.
Likes Jen2114
So dEx=(1/4πε)*((2πσrx)/(x^2+r^2)^3/2)) is the electric field component in the x direction and so when you integrate to obtain the electric field for all the small rings in the disk , you are working your way out towards R, the radius of the entire disk. So that's why you integrate from 0 to R and not -R to R?
It's easy,see?
You've forgotten the dr in your formula.
Likes Jen2114
Ahhh ok I see thanks. Yeah, super clear now. Thanks I'll add the dr. Thanks again!
You're welcome.I'm studying for an E-M exam right now anyway,so it's good use of my time.
Likes Jen2114
