Implementing F(X,Y,Z) with 4 Chips
  • Thread starter EvLer
In summary, you are given 4 chips: 2-input NAND, 2-input NOR, NOT and 3-input NAND gate chips to implement the following functions: *- AND, + OR, '-NOT. You are also given a dual of F. You are trying to simplify the expression and are having difficulty doing so. You have tried different things but are not able to simplify it. If something is still not clear, please...tell me again, English is your 2-nd language after all. You are given 4 chips: 2-input NAND, 2-input NOR, NOT and 3-input NAND gate chips
EvLer
458
I am given 4 chips: 2-input NAND, 2-input NOR, NOT and 3-input NAND gate chips to implement following functions (*- AND, + OR, '-NOT):
F(X, Y, Z) = X*(Y' + Z) + X'*Y
F'(X, Y, Z) and a dual of F... all simultaneously.
Input are DIP switches.
Dual i have not figured out yet, complement should be easy: just run the output of F through the inverter.
But i have a concern: the way i designed F is that I run A LOT of stuff through the inverter, and my breadboard is all in wires. And so far i have not used 3-input NAND, maybe it would be used with dual (since i have to change operators). Is there an easier way (that i don't see) to implement F?
I was trying to simplify the expression and I would get
X(xor)Y + Z*X, but i am not supposed to use XOR chip.
Any help is very much appreciated.
Your wording is not clear. Can you state what you are after more clearly?
KM
yeah, sure, attempt #2:
* stands for logical AND, + for OR, ' for NOT (just explaining notation i use)
so, i need to implement simultaneously these logical expressions (F, F', dual of F - shown below) on my breadboard using chips: NAND (2-input), NAND (3-input), NOR (2-input) and hex inverter (NOT gate or 74HC04).
F = X*(Y' + Z) + X'*Y
so, the way i implemented F function so far looks very crowded on my breadboard. For example: for X*(Y' + Z) i had to run a wire (Y) through inverter then connect it and wire for Z to the NOR and then connect output from NOR back to the inverter, since i need OR and not NOR...
so I am wondering if i am missing some logic simplification, i have tried different things but cannot simplify it. XOR is not allowed.
If something is still not clear, please...tell me again, English is my 2-nd language after all :)
How many "Gates" are you given? My guess is the following:
four- 2 input AND (on one chip)
four- 2 input NOR
three- 3 input NAND
six- INVERTERS
Is this correct?
First, I'd suggest defining the exact terms of F'. Then put F and F' so that they both have the same input terms (one will be inverted and have to be re-inverted at the end). Finally, combine the like terms and put them into two (3 input) NANDS to get the two functions (one will be inverted).
Erm...sorry, you're right: each chip has several gates.
Thank you for clarification there :redface:
Each input-output pair of pins can be used only once, right?
so do you forsee usage of the hex inverter A LOT, like it seems to me?
Generally, inputs can be used only once, but outputs can be fanned out all over the place. Offhand, I see a most likely use for four inverters, one for each of the inputs, and one for one of the gate outputs.
KM
Thing is ... that i need to implement 3(!) functions on one breadboard at the same time: that function F, it's complement F' (easy...just hook it up to the inverter and get the output) and it's dual, which i think should be something like reversing operators from AND to OR and from OR to AND, so from F i would get a F(dual): X+(Y'*Z) * X' + Y, not sure about parenthesis though...and not sure that i would have enough space on the breadboard.
Question: What do you mean by 3(!) functions? The only things that I see that you need, are F and F(dual).
Do the following:
1) Put F into its Simple Sum Of Products form, ie. - - - (A*B)+(C*D)+(E*G).
2) Get F(dual) from F. It will be in a Simple Product of Sums SPOS) form, ie (A + B)*(C + D)*(E + G), to correspond to F.
3) Find F(dual)', which will then also be in SSOP form.
4) Use these values to wire the gates. Remember, that SSOP is implemented by simply taking the items that are now being And'ed (the terms within the parentheses) into NAND's. These outputs are then Or'ed by taking the proper outputs (inverted) from the NANDs, and sending them to additional NANDs. In other words, we get the ANDs to ORs functions, by using NANDs to NANDs.
5) Finally, the F(dual)' has to be inverted (put through an inverter, to get F(dual).
Note: I hate using such representations as N' instead of {N with a 'bar' over it}, but I understand that the limitations of Microsoft and HTML force it. It makes manipulating Logic equations messy.
KM
thanks for more explanation and hint on SSOP, but question:
for a function A*B + C*D, wouldn't the dual be (A + B) *(C + D) or does the negation also apply?
thanks much.
EDIT: what i meant by 3 functions was: F, F' and dual of F.
thanks much.
You are correct; the dual is not negated; that isn't done until the actual negation is taken.
So if you have: F = (A + B)*(C + D)*(E + G)
The Dual is: F(dual) = (A * B) + (C * D) + (E * G)
And: F(dual)' = (A' + B') * (C' + D') * (E' + G')
The reason for the question about the three functions is: Does the solution call for giving an output for both the dual and its negation or just the dual?
(The difference is only the matter of an inverter on the output.
KM
1. Can F(X,Y,Z) be implemented using only 4 chips?
Yes, it is possible to implement F(X,Y,Z) using only 4 chips by utilizing the available logic gates and designing a circuit that can perform the required operations.
2. What are the necessary components needed for implementing F(X,Y,Z) with 4 chips?
The necessary components for implementing F(X,Y,Z) with 4 chips include logic gates such as AND, OR, and NOT gates, as well as flip-flops and decoders.
3. Is it more efficient to implement F(X,Y,Z) with 4 chips compared to using more chips?
It depends on the complexity of the function and the available resources. In some cases, using more chips may result in a more efficient implementation, while in others, using fewer chips can be more efficient.
4. How can I test the functionality of the F(X,Y,Z) circuit implemented with 4 chips?
To test the functionality of the F(X,Y,Z) circuit, you can use input values and compare the output with the expected result. You can also use simulation software to simulate the circuit and check for any errors or bugs.
5. Are there any limitations to implementing F(X,Y,Z) with 4 chips?
There may be limitations depending on the complexity of the function and the capabilities of the chips being used. Some functions may require more chips to be implemented efficiently, while others may not be possible to implement with only 4 chips.
  • Electrical Engineering
  • General Math
