Circular motion and speed of rotation
The discussion revolves around calculating the speed of rotation and tension in a 'chair-o-plane' ride with specific parameters. The user successfully calculated the rotation speed at approximately 11 RPM but struggled with determining the tension in the chain due to having two unknowns in the equations. A suggestion was made to assume the mass of the chair is negligible compared to the rider's mass to simplify the calculations. However, a warning from a professor highlighted the importance of academic integrity, indicating that using external help could lead to serious consequences. The conversation emphasizes both the mathematical challenge and the ethical considerations in academic work.
kikifast4u
There's a 'chair-o-plane' with a radius of 4m and the seats are connected using 3m chains.
a) Calculate the speed of rotation at which the chains make an angle of 35 to the vertical
b) What is the tension in the chain if a rider of 90kg is on the swing at the speed above?
Newton's laws, Centripetal force formula, Trigonometric formulas
I did a) and found a reasonable value of about 11RPM.
However I have a problem with b).
I get to equations, T'*sin(35)=g(M+m) and T'*cos(35)=a(M+m), where T' is the tension and M and m are the masses of the rider and the chair. Since I have a=g*tan(35) (from a) ), the two equations above are equivalent and I therefore have one equations with two unknowns. Am I missing something? How can I get m in order to find T'?
hi kikifast4u! :smile:
i think you're supposed to assume that the mass m of the chair is negligible compared with the mass M of the rider, ie that m = 0 :wink:
I do hope so. Otherwise I don't think I have enough data to get a numerical value. Thanks!
kikifast4u,
This is professor George, i believe by signing the Own Work declaration you agree not to use the help of any external agency to solve your Assignments.
This is viewed by the university as a serious offence.
I had a look at your paper and i already got your name, your assignment won't be corrected or graded unless you head to the ETO and confess you used external help.
Failure to do so will result in more than losing grades.
Thank you.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
