Circular Motion/Gravitational Acceleration Help Needed
The discussion revolves around two physics problems involving circular motion and gravitational acceleration. For the first problem, the tension in a cord holding a 1.84 kg ball swung in a vertical circle needs to account for both gravitational and centripetal forces, requiring a free body diagram for accurate calculation. The second problem involves calculating gravitational acceleration at a specific height above Earth's surface, using the formula g = GM/r², where the radius must include both Earth's radius and the height above it. Participants emphasize the importance of considering the effects of gravity in vertical circular motion and the correct application of formulas. Understanding these concepts is crucial for solving the problems accurately.
FLIHGH
Hi, I am having problems with the following two problems:
A 1.84kg ball is swung vertically from a 0.80m cord in uniform circular motion at a speed of 2.8m/s. What is the tension in the cord at the bottom of the ball's motion?
I have tried using the centripital acceleration formula to find a, and then plugged it into the tension formula of T=ma (is that even right?), but cannot get the correct answer.
w²r = (1.84*pi)² * 0.8 = 2.67 m/s²
Tension = ma = 2*2.67 = 5.34 N
The second problem is:
The radius of the Earth is 6.38E6 m and its mass is 5.98E24 kg. What is the acceleration due to gravity at a height of 27391854.50m above the Earth's surface? (We are given that G = 6.67e-11 N*(m^2/kg^2))
I have tried using G = 6.67e-11 N*(m^2/kg^2) to find the acceleration, as well as g= -GM/r^2, but cannot come up with anything.
I have used g= -GM/r^2, and plugged in 5980000000000000000000000 for M and 6380000 for r, but nothing is coming out correct.
Thanks in advance!
Tension = ma = 2*2.67 = 5.34 NThanks in advance!
Hii FLIHGH ! Welcome thee to PF !
For first problem , its given that ball is swung in a "vertical" circle. You can't just apply those formulas directly.
Hint: Consider the free body diagram of the ball when it is at bottom , making an angle 0o with vertical. Then apply Newton's second law and form an equation. Resultant force contributes to centripetal acceleration.
Thank you for the response-- what exactly is a vertical circle?
Might you consider this animation of motion in vertical circle :http://www.learnerstv.com/animation/animation.php?ani= 40&cat=physics
Or see here (if your QuickTime player is not out of date) : http://phys23p.sl.psu.edu/phys_anim/mech/embederQ2.30050.html
In short , how would you solve this problem if it was a horizontal circle ? You would just put tension in string equal to centripetal force , and solve for it. In vertical circle (take a ball tied to a string and revolve it with the help of your ball and socket joint , in a plane perpendicular to ground) , gravity also plays the role. Centripetal force is resultant force of gravity and tension of string in a vertical circle. Also , its variable and depends on angle with vertical , for a given radius in vertical circle.
Now once you realize what a "vertical circle" is , get back on post #2 , and follow the hint I gave..
Thanks in advance!
All you need to do with this is combine your two formulas of Fg=(GMm)/r^2 and Fc=(mv^2)/r=ma
this then cancels out the mass of the smaller object so we don't need to worry about that, then by solving the equation for a, we are able to see the acceleration due to gravity at a certain point above the Earth's surface :approve:
just got to make sure that you take into account the radius of the point from Earth's centre of gravity...
That will affect the Fg value...
So just add the radius of the Earth to your given radius value :approve:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
