Circular Motion Problem: Finding Angular Velocity with Maximum Tension of 50 N
To find the angular velocity of a ball in circular motion with a maximum tension of 50 N, the correct approach is to equate the tension force to the centripetal force, represented as mv²/r. The mass of the ball is 0.5 kg and the radius is 1.5 m. The mistake in the initial calculation was equating mv²/r to mg instead of the tension. The correct calculation shows that the angular velocity (w) should be 8.16 rad/s, highlighting the importance of maintaining proper unit conversions and relationships in physics problems. Understanding these principles is crucial for accurate problem-solving in circular motion scenarios.
anonymous820
A ball of mass .5 kg is attached to the end of a cord whose length is 1.5 m. The ball is whirled in a horizontal circle. If the cord can withstand a maximum tension of 50 N, what is the angular speed the ball can have before the cord breaks?
m (mass) = .5 kg
r (radius) = 1.5 m
Ft (tension force) = 50 N
w (angular velocity) = ?
w = v/r
Ft = Fg
m v^2/r = mg
v^2/r = g
v^2/1.5 = 9.81
v^2 = 14.715
v = 3.836 m/s
w = 3.836/1.5
w = 2.557
so my question is..what am i doing wrong? because the answer is [angular velocity (w) = 8.16 rad/s]
What you are doing wrong is equating mv^2/r to mg. The tension force is mv^2/r. You want to equate that to the 50N string strength.
Uh, v=w*r NOT w=v*r! Pay attention to units! v=m/sec, w=1/sec, r=m.
S'ok. Don't EVER do that again. It the sort of mistake that allows people to laugh at you and it's easily avoided. Carry the units along and you can easily see where you've goofed big time. Just trying to save you future humiliation.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
