Circular Motion - Roadway Bank Angle
A 3000-pound car negotiating a circular interchange with a radius of 300 feet at 30 mph requires calculations to determine the force between the tires and the road to prevent skidding. The centripetal acceleration must be calculated using the car's speed converted to meters per second. The angle of the roadway banking is derived from the formula θ = tan-1(v² / rg), where g is the acceleration due to gravity, typically 9.8 m/s². Converting the radius from feet to meters is necessary for accurate calculations. Understanding these physics principles is essential for solving the problem effectively.
JeffNYC
A) 3000 pound car is negotiating a circular interchange or radius 300ft at 30mph. Assuming the road is level, find the force between the tires and the road such that the car stays on the circular path without skidding.
B) Next, Find the angle at which the roadway should be banked so that no lateral force is exerted on the tires of the automobile.
F = ma
m = 3000/32
tanθ = v^2 / rg
θ = tan-1(v^2 / rg ) .
v = velocity of the vehicle = 30
r = radius of banking = 300
g = accleration due top gravity
I really don't know - this is a question from a calculus course and is one of the more challenging problems at the chapter's end. Having never taken even introductory physics, if anyone could help me out with the calculations + brief explanation that would be wonderful.
Jeff
F = ma
m = 3000/32
tanθ = v^2 / rg
Jeff
The first question is asking you what the centripetal acceleration on the car is. You converted your weight to mass, but you need to convert your speed to seconds to make this calculation correctly. (Once you have the acceleration you use the mass to determine the force.
The second part is asking where the lateral forces on the tires (similar to what you just calculated but taking the angle into account) will balance with the inward component of weight down the incline. Since they are supposed to balance you need not be concerned with friction.
So,
1 mph = 0.44704 meters per second
30mph = 13.4112 meters per second
Centripetal Acceleration = (13.4112`^2)/300
= 0.599534*mass = .5999534*93.75 = 56.2063
So I have my acceleration now.
So, θ = tan-1(v^2 / rg )
= arctan(179.86/300g)
what do I use for "g"?
JeffNYC said:
So,
If you are using meters per second then 9.8m/s2 is the acceleration you need.
But you also need to convert 300 feet to meters too.
