Circular Motion - Wall of death Problem
The discussion revolves around a problem related to circular motion, specifically the dynamics of a motorcycle on a wall of death. Participants are tasked with finding the minimum and maximum speeds required to maintain the motorcycle's position against gravitational forces and frictional effects.
  • Mixed
  • Participants explore the relationship between speed, gravitational forces, and friction, questioning the calculations for minimum and maximum speeds. There is an attempt to derive equations based on the forces acting on the motorcycle.
Some participants have provided calculations and expressed uncertainty about their correctness. Others have raised questions regarding the maximum radial force and its relationship to the motorcycle's speed, indicating a collaborative effort to clarify the problem.
Participants are working under the constraints of given mass, coefficient of friction, radius, and maximum gravitational force, while also grappling with the conversion of gravitational force into Newtons for their calculations.
blackbird2552
Total mass = 260 kg
Coefficient of Friction = 1.00
r = 4 m
gmax = 4 g
a) Find the minimum speed to keep the rider on the wall of death.
b) Find the maximum speed inside the wall of death of the motorcycle based on gmax
[tex]\mu[/tex] x (mv^2/r) = mg
Fc = mv^2/r
Gforce = mv^2/r
a)
V = [tex]\sqrt{ g r / \mu}[/tex]
V = 6.26 m/s
b)
Gforce = mv2/r
4 = 0.26g x v2 / 4 m
V = 7.84 m/s
I don't know if it is right...
blackbird2552 said:
Total mass = 260 kg
r = 4 m
gmax = 4 g
Correct.
b) Find the maximum speed inside the wall of death of the motorcycle based on gmaxGforce = mv2/r
V = 7.84 m/s
I can't follow your reasoning. What is the maximum radial (normal to the wall) force (in Newtons)? What is the relationship between that force and the speed of the motorcycle? What is the motorcycle speed needed to achieve that force?
AM
..what i need to do is find is the maximum speed at which the motorcycle should be going to get the max value of g, that is 4 gs...i don't get how i will calculate it!...what i did is, since Fc = mv^2/r...the gforce = mv^2/r., i had the mass and the radius...i solved it for v...i think i should convert the 4 g to the force in Newton that would be the maximum radial (normal to the wall) force (in Newtons)...i don't know how to do that...help?...
i think i got where i went wrong in the second one
The total force acting when the mass is experiencing 4 gs is
4g = 39.24 m/s2
F = ma
F = 260 kg x 39.24 m/s2 = 10202.4 N
to get the max v
Fc = mv2/r
10202.4 = 260kg x v2 / 4 m
V = underoot 156.96
V = 12.5 m/s
Is this right??...
4g = 39.24 m/s2
F = ma
to get the max v
Fc = mv2/r
V = underoot 156.96
V = 12.5 m/s
Is this right??...
Correct.
AM
