How High Does the Ball Rise in a Rotating Bowl?
In summary, a ball with a mass of 50 grams is placed inside a circular bowl with a radius of 10cm. The bowl is rotating at a rate of 5 hertz. The question is asking for the height in centimeters that the ball will rise within the bowl. The solution involves finding the normal force exerted by the bowl on the ball, which has a horizontal component that acts as the centripetal force and a vertical component that causes the ball to rise. However, if there is no friction, the ball will not rise and will remain at the bottom of the bowl.
Isiudor
23
the bowl rotates at a rate of 5 hertz
what is the height in cms the ball will rise within the bowl?
Fr = m*w^2/r
[tex]\sum[/tex]F = ma
well the solution is pretty obvious to me;
since we are talking about max height then Fnety = 0 hence N*cosa = mg and N*sina = m * w^2/r.
the problem is I don't understand why the ball would move at all, what force is the bowl exerting on the ball? there is no mention of friction and the ball initially has no inertia of it's own, how does the spinning bowl effect it without friction?
that is when we assume the ball is already rotating in a certain height within the bowl at the same rate as the bowl.
what I am asking is why does the bowl exert any force on the ball at all
say, we place the ball in the dead center of the bowl and then begin rotating the bowl, there's no friction, why doesn't the ball simply stay in the bottom? there's no force acting on it.
oh. in that case you are quite right. the ball would presumably just remain at the bottom of the bowl without spinning at all if there's no friction. if there's no friction at all the ball wouldn't even undergo circular motion at the same rate as the ball, so i think for this question you have to assume friction and that the ball started off slightly "off-center" from the bottom of the bowl (else there will be no horizontal vector accounting for the centripetal force).
I can understand your confusion about the forces at play in this scenario. In circular motion, there are two main forces at play: the centripetal force, which is directed towards the center of the circle and keeps the object moving in a circular path, and the centrifugal force, which is directed away from the center and is a result of the object's inertia trying to keep it moving in a straight line. In this case, the bowl is providing the centripetal force to keep the ball moving in a circular path. Even without friction, the ball will still experience a force from the bowl, as the bowl is constantly changing the direction of the ball's motion. This force is known as the normal force, and it is perpendicular to the surface of the bowl.
In order to calculate the height the ball will rise within the bowl, we can use the equation you provided, Fr = m*w^2/r. This equation relates the force of the normal force (N) to the mass of the object (m), the angular velocity (w), and the radius of the circle (r). By rearranging this equation, we can solve for the height (h) as h = (N/m)*r.
In this scenario, we can assume that the ball is not sliding or slipping on the surface of the bowl, so there is no friction present. This means that the normal force is equal to the weight of the ball (N = mg). Plugging in the given values, we can calculate the height as h = (0.05 kg*9.8 m/s^2*0.1 m)/(0.05 kg) = 0.098 m, or 9.8 cm.
I hope this explanation helps to clarify the forces at play in circular motion, and how they affect the motion of the ball in the bowl.
Related to How High Does the Ball Rise in a Rotating Bowl?
What is circular motion?
Circular motion is when an object moves in a circular path around a fixed point, also known as the center of rotation. This type of motion is characterized by a constant distance from the center and a constant speed along the circular path.
What is the difference between uniform circular motion and non-uniform circular motion?
Uniform circular motion is when an object moves in a circular path at a constant speed, while non-uniform circular motion is when the speed or direction of the object is changing along the circular path.
What is centripetal force?
Centripetal force is the force that acts towards the center of rotation and keeps an object moving in a circular path. It is required to maintain the object's constant speed and direction in circular motion.
How is circular motion related to Newton's laws of motion?
Circular motion is related to Newton's laws of motion as it follows the first law, which states that an object will remain in motion in a straight line at a constant speed unless acted upon by an external force. In circular motion, the object's velocity is constantly changing due to the centripetal force acting on it.
What are some real-life examples of circular motion?
Some examples of circular motion in everyday life include a car going around a curve, a satellite orbiting around the Earth, and a spinning top. Ferris wheels and merry-go-rounds also demonstrate circular motion.
