songoku
- 2,329
- 337
Why an object will move in circular when the acceleration is perpendicular to the velocity?
It may not be intuitive to you but read FactChecker's reply carefully (and rigorously). His argument is sufficient if you follow his logic.songoku said:Why an object will move in circular when the acceleration is perpendicular to the velocity?
Circular motion is when an object moves along a circular path or trajectory. It is defined as a type of motion in which an object moves at a constant speed along a circular path, with the direction of motion constantly changing. This means that the object is constantly accelerating, even though its speed remains constant.
This is due to the fact that acceleration is a vector quantity, meaning it has both magnitude and direction. In circular motion, the direction of the object's velocity is constantly changing, even though its speed remains the same. This change in direction results in a changing acceleration, causing the object to accelerate perpendicular to its velocity.
Centripetal acceleration is the acceleration of an object moving in a circular path, while centripetal force is the force that causes the object to move in that circular path. These two quantities are inversely proportional, meaning that as one increases, the other decreases. This means that in order to maintain circular motion, the centripetal force must be equal to the centripetal acceleration.
Yes, there are many real-life examples of circular motion. Some common examples include the motion of planets around the sun, the motion of a car around a curved road, and the motion of a ball in a game of basketball. Any object that moves along a curved path or trajectory can be considered to be in circular motion.
Centripetal force is the force that keeps an object moving in a circular path, while centrifugal force is a fictitious force that appears to push an object outwards from the center of rotation. In reality, centrifugal force is simply the result of inertia, or an object's tendency to resist changes in its motion. It is not a true force, but rather a perceived force due to the object's inertia.
