B Understanding the Circumference of a Circle: A Comparison of 2π and 2πr
The discussion clarifies that the circumference of a circle can be expressed as both 2π and 2πr, depending on the context. When referring to a unit circle with a radius of 1, the circumference is simply 2π. If the radius is any value r, the correct formula is 2πr. The confusion arose from a reference to the unit circle in the Thomas/Finney Calculus textbook. Understanding the distinction between the unit circle and circles of different radii resolves the initial question.
Shafia Zahin
I just have a little question that i have read in the book of Thomas/Finney Calculus 9th edition that the circumference of a circle is 2pi,i can be wrong obviously but wasn't it supposed to be 2*pi*radius of the circle?
Please help.
Mathematics news on Phys.org
Please help.
Both are correct if the radius r = 1. Can you scan the page in question and UPLOAD it?
Likes Shafia Zahin
Most likely, they calculated the length of the curve ##y = \sqrt{1 - x^2}##. This is the unit circle with radius ##1## and thus the circumference is equal to ##2\pi##.
If they would have calculated the length of the curve ##y = \sqrt{r^2 - x^2}##, the circumference would be equal to ##2\pi r##. This is the circle through the origin with radius ##r##.
Likes Shafia Zahin
Oh, yes, thank you, they have said about the unit circle at first then said that it's circumference is 2pi. Sorry,I didn't notice . But thank you again, I was really confused.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
