How Do Voltage and Current Behave in Series and Parallel Light Bulb Circuits?
  • Thread starter Thread starter Fire Slayer
    Light
In a parallel circuit with two light bulbs rated at 30W and 40W, each bulb experiences the same voltage of 120V, resulting in different currents based on their power ratings. The resistance for each bulb can be calculated using the formula R = V^2 / P, yielding specific values for both bulbs. In contrast, when connected in series, the total voltage of 120V is divided between the bulbs, leading to a shared current throughout the circuit. The voltage drop across each bulb in series is proportional to its resistance, affecting the overall brightness. Understanding these behaviors is crucial for analyzing circuit performance in different configurations.
Fire Slayer
Two Light bulbs, one rated 30W at 120V and another rated 40W at 120V are arranged in two different circuits.
a) they bulbs are connected in parallel to a 120V source
determine the resistance and current in both bulbs.
b) determine the resistance and current if they are connected in series
P=IV
V=IR
I took the power over the voltage to find the current and then plugged that into V=IR, but how does the voltage and current differ when it splits, or when it is in series?
The load voltages for a parallel configuration is the same across each load. Each light in the parallel configuration has the same voltage.
For a series configuration the load voltages add to equal the source voltage.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
