Classical mechanics and specific relativity
The discussion revolves around calculating the time it takes for neutrons from the sun to reach Earth and the differences between classical mechanics and special relativity in this context. It is clarified that if the speed of the neutrons is a significant fraction of the speed of light, special relativity must be applied for accurate results; otherwise, classical mechanics suffices for slower speeds. The assumption that neutrons travel at the speed of light is deemed unreasonable, as neutrons are massive particles and do not travel at that speed. Additionally, the prediction regarding neutrons slowing down and decaying upon reaching Earth is considered reasonable, given their short half-life. The conversation emphasizes the importance of understanding the speed of particles when determining the appropriate physics framework to use.
nuclear
i was asked to calculate the time that the neutrons from the sun reach the earth. i had no problem with that but my problem comes from the 2nd part.
i was asked "would you expect a solution based on classical mechanices to differ significantly from one based on special relativity and why?"
what i thought is: there's no difference since the speed of light is the same in the inertial frame since light travel through the vacuum to reach the Earth without being affects by gravity.
is that thought valid? i dun have much knowledge in relativity.
also, i was asked to predict what will happen to the neutrons that reach the Earth with their full initial energy and then slow down to thermal equilibrium with atoms in the atmosphere.
my answer: neutrons slow down due to the decrease in temperature and decay since its halflife is just 10.25 minutes and it took 8.3 minutes to reach the earth.
again, is that reasonable?
thanks for your help. appreciate that
Generally, if the speed of the particle is a significant fraction of the speed of light then special relativity is needed for an accurate answer. For slow (compared to light) speeds, classical mechanics works just fine. How fast were the neutrons going compared to the speed of light?
no, the speed of the neutron is not given and i assumed the neutron travel at the speed of light to earth. is it reasonable?
so i guess the answer won't differ too signigicantly since the law of physics works under different frame and just the classical mechanics is not that good dealing with light speed? is that valid?
No.
I don't understand your statement. As I said earlier, the closer the speed is to that of light, the more you need to apply special relativity to get accurate results.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
